Wave interference and resolving resultants
In summary, two sinusoidal waves with identical wavelengths and amplitude, but different phases, travel in the same direction along a stretched string. When they interfere, they produce a resultant wave given by x(z,t) = 3Cos (20z-4t+0.82). By using trigonometric identities and equations for cosines, we can determine the wavelength, phase difference, and amplitude of the two original waves.
kel
62
Me again !
I have the following question and this time I really have no idea!
2 sinusoidal waves, identical except for their phase, travel in the same direction along a stretched string and interfere to produce a resultant wave given by:
Where x is in mm, z in metres and t in seconds
a- What is the wavelength of the 2 original waves
b- What is the phase difference between them
c- What is their amplitude
At the present I'm stuck on 'a' and may/may not be able to do b and c once I know how to work out 'a'.
I can see how to add original waves, but how do I go about resolving the resultant wave? I guess it's similar to vector algebra, but mmmmm... really don't know where to begin on this one.
Any help would be very much appreciated.
This should get you started:
[tex]\sin \alpha + \sin \beta = 2 \cos \left( \frac{\alpha - \beta}{2} \right) \sin \left( \frac{\alpha + \beta}{2} \right)[/tex]
You'll have to excuse me for being a bit clueless here, but how do I relate that to the resultant wave?
Sorry, it's late and my brain needs caffine!:zzz:
Cheers
Adding the two waves gives you the resultant wave.
Use the fact that the waves are identical, except for phase, to write equations for the two waves.
So far, I've got the following
y(z,t) = 3cos(20z-4t) + 3cos(20z-4t+0.82)
but I don't think this is right
The two waves, identical except for phase:
[tex]
y(z,t) = A\cos(kz - \omega t + \phi_1) + A\cos(kz - \omega t + \phi_2)
[/tex]The earlier equation for cosines:
[tex]\cos \alpha + \cos \beta = 2 \cos \left( \frac{\alpha - \beta}{2} \right) \cos \left( \frac{\alpha + \beta}{2} \right)[/tex]
Can you now see where we're going?
So, I'd get
[tex]\cos \alpha + \cos \beta = 2 \cos \left( \frac{\0 - \0.82}{2} \right) \cos \left( \frac{\0.82}{2} \right)[/tex]
Which leaves
[tex]\cos \alpha + \cos \beta = 2 \cos \left(-0.41\right) \cos \left(0.41\right)[/tex]
I get:
[tex]y(z,t) = A\cos(kz - \omega t + \phi_1) + A\cos(kz - \omega t + \phi_2)[/tex]
[tex]y(z,t) = 2A \cos\left(\frac{\phi_1-\phi_2}{2}\right) \cos\left(\frac{2kz - 2\omega t + \phi_1 + \phi_2}{2}\right)[/tex][tex]y(z,t) = A' \cos \left( kz - \omega t + \frac{\phi_1 + \phi_2}{2} \right)[/tex] , where
[tex]A' = 2A \cos \left(\frac{\phi_1-\phi_2}{2}\right)[/tex]
Now this looks quite a bit like the equation given in the problem.
I tried it like this (adding two waves together):
a*sin(kx-wt+PI/2) + a*sin(kx-wt+PHI+PI/2) ---> a*cos(kx-wt) +
a*cos(kx-wt+PHI).
adding these using the trig identities you get:
2a*cos(kx-wt+PHI/2)*cos(-PHI/2).
comparing this with the resultant wave, then:
k = 20
w = 4 and
PHI/2 = 0.82.
and using k = 2PI/Lambda and w=2P
wave 2a = 3 this would suggest that the amplitude is 3/2.
Good :smile:.
The thing I'll have to disagree about is the amplitude. The latter cosine term, cos(-PHI/2) = cos(PHI/2), contributes into the amplitude (see A' in my previous post).
FAQ: Wave interference and resolving resultants
What is wave interference?
Wave interference is a phenomenon that occurs when two or more waves meet and interact with each other. The resulting wave is a combination of the individual waves and can exhibit different properties, such as a change in amplitude or wavelength.
What causes wave interference?
Wave interference is caused by the superposition of waves, which is when two or more waves overlap and combine their amplitudes. This can occur when two waves with the same frequency and wavelength travel through the same medium, or when a wave encounters a barrier or obstacle.
What is the difference between constructive and destructive interference?
Constructive interference occurs when two waves with the same frequency and amplitude meet and combine to produce a wave with a larger amplitude. Destructive interference, on the other hand, occurs when two waves with the same frequency but opposite amplitudes meet and cancel each other out, resulting in a wave with a smaller amplitude.
How do you calculate the resultant of multiple interfering waves?
To calculate the resultant of multiple interfering waves, you can use the principle of superposition. This involves adding the individual waves together at each point in space and time. The resulting wave will be the sum of all the individual waves and its properties can be determined using the rules of wave addition.
What is the importance of resolving resultants in wave interference?
Resolving resultants is important in understanding and predicting the behavior of waves in various situations. It allows us to determine the properties of the resulting wave and how it will interact with its surroundings. This knowledge is crucial in many fields, including optics, acoustics, and electromagnetic waves, and has practical applications in technologies such as radar and sonar.
