Wave speed for non-uniform density?
In summary, the speed of the wave pulse changes as it moves up the rope due to the increased tension.
Blue_Angel
A long rope with mass m = 10 kg is suspended from the ceiling and hangs vertically. A wave pulse is produced at the lower end of the rope and the pulse travels up the rope.
(a) Explain why the speed of the wave pulse change as it moves up the rope; does it increase or decrease?
(b) What will happen to the wave pulse if a section near the middle of the rope has been soaked in water shortly before the rope was hung from the ceiling?
v=sqrt(T/(m/L))
For part a v increases as height increases because there's greater tension...
My problem is with part C, I think soaking the string in water would increase the mass of the string near the centre section, however this means it would also increase the tension proportionally. Because wave speed is dependant on the ratio of the tension to mass the wave speed before it was soaked in water would be exactly the same as the wave speed after.
To put this into equation form v=sqrt(T/(m/L)) where T=mg so v=sqrt(Lg), The velocity has no dependence on mass.
can someone verify whether this is true or false??
T is not just mg. If it were you wouldn't have answered part A the way you did. I bet you can write a better expression for T as a function of position along the length.
Also, notice that it isn't really m in your speed equation. It is m/L, a linear density. It asumes the density is constant over the length. That isn't the case anymore when the middle is wet.
Ok but if T were tension at a point on the string and Y was how high up the point was, can I say
T=mg*(Y/L)
therefore v=sqrt((mg(Y/L))/(m/L))=sqrt(gY)
Right for the case without water, and notice you now have your expression with explicit dependence on Y for answering part A.
Now can you write an expression for T vs Y including the water? You will also have to replace m/L with an expression for density vs Y. You'll get 3 results for the three regions: below the water, in the water, and above the water.
Under the water would be exactly the same as above. Through the water density has increased a lot but tension is scarcely changed so velocity will decrease? and above the water density would be low but tension would be very high because of the added mass so it speeds up?
Uhmm... I wrote out the solutions on a white board and then erased them. Let me think. Yes, that sounds right.
Related to Wave speed for non-uniform density?
1. What is wave speed for non-uniform density?
Wave speed for non-uniform density refers to the speed at which a wave travels through a medium that has varying density. This means that the particles in the medium are not evenly distributed, which can affect the speed of the wave.
2. How does non-uniform density affect wave speed?
Non-uniform density can affect wave speed in several ways. If the density increases, the wave speed will decrease because the particles are closer together and it takes longer for the wave to pass through them. On the other hand, if the density decreases, the wave speed will increase because the particles are more spread out and the wave can travel faster.
3. What factors can contribute to non-uniform density in a medium?
There are several factors that can contribute to non-uniform density in a medium. These include changes in temperature, pressure, or composition of the medium. For example, in the ocean, the density of water can vary due to differences in temperature and salinity.
4. How is wave speed for non-uniform density calculated?
The wave speed for non-uniform density can be calculated using the equation v = √(K/ρ), where v is the wave speed, K is the bulk modulus of the medium, and ρ is the density of the medium. This equation takes into account the non-uniform density of the medium and provides a more accurate calculation of the wave speed.
5. Why is it important to consider non-uniform density when studying wave speed?
It is important to consider non-uniform density when studying wave speed because it can significantly affect the behavior of waves in a medium. Waves can refract, reflect, and diffract differently in areas with varying density, which can have important implications in fields such as oceanography and seismology. Understanding the effects of non-uniform density on wave speed is crucial for accurately predicting and interpreting wave behavior in different mediums.
