Wavefunction collapse with a single photon?
In summary: This makes it difficult to observe the entire slit area at once, as the photons would need to be perfectly aligned to fully block it out. In summary, observing part of the wavefunction of a particle always causes collapse, even if the probability distribution does not indicate the particle's presence. This is due to the interaction of photons with the wave, acting like a wall that blocks out parts of the wave and causing collapse. It is possible to observe one of the slits in a way that only partially blocks the wave, resulting in an altered interference pattern. However, fully blocking out a slit is impossible due to the quantized nature of photons.
Xilor
152
Hello, I was wondering what exactly happens when you observe part of the wavefunction of a particle, does this always cause collapse? Or only when the probability distribution decides that the particle is indeed there?
What I mean is, is an observation in the form of photons interacting with the wave more like a wall that cancels out part of the wave if the particle isn't there, or does it always cause full collapse?
If its always full collapse, why isn't the wall with the slits in it causing collapses? Why don't random photons in the area cause collapses (such as those from blackbodyradiation of the instruments)?
If it just blocks out parts of the wave, isn't it possible to try to observe one of the slits in such a way that not the entire wave is blocked out, still causing an interference pattern but an altered one? If that is possible, how can you ever fully block out a slit? It seems impossible to observe the entire slit area at once since photons are quantized.
Observing part of the wavefunction of a particle always causes collapse, regardless of whether or not the probability distribution decides that the particle is there. This is because the act of observation itself changes the wavefunction by introducing a new factor into it which changes its shape. The photons interacting with the wave act like a wall that blocks out part of the wave, thus causing collapse. This is why the wall with the slits in it causes collapses, as photons from the instrument interact with the wave and cause collapse. Random photons in the area may also cause collapse if they are energetic enough to interact with the wave. It is possible to try to observe one of the slits in such a way that not the entire wave is blocked out, still causing an interference pattern but an altered one. However, it is impossible to fully block out a slit as photons are quantized and therefore can only interact with the wave in discrete amounts.
Related to Wavefunction collapse with a single photon?
1. What is wavefunction collapse with a single photon?
Wavefunction collapse with a single photon refers to the phenomenon in quantum mechanics where the wave-like behavior of a photon, which is a fundamental particle of light, is reduced to a specific location or state through measurement or interaction with another particle.
2. How does wavefunction collapse occur with a single photon?
Wavefunction collapse with a single photon occurs when a measurement or interaction is made with the photon, causing its wave-like behavior to collapse to a specific location or state. This is due to the probabilistic nature of quantum mechanics, where the photon exists in a superposition of states until it is observed.
3. What are the implications of wavefunction collapse with a single photon?
The implications of wavefunction collapse with a single photon are significant in the field of quantum mechanics, as it challenges our understanding of the fundamental nature of particles and their behavior. It also has practical applications in technologies such as quantum computing and cryptography.
4. Can wavefunction collapse with a single photon be observed?
Yes, wavefunction collapse with a single photon can be observed through experiments and measurements in quantum mechanics. However, it is important to note that the act of observation itself can cause the collapse, making it a challenging concept to study.
5. How does wavefunction collapse with a single photon differ from wavefunction collapse with multiple particles?
Wavefunction collapse with a single photon differs from wavefunction collapse with multiple particles in that it involves the collapse of a single particle's wavefunction, while the latter involves the collapse of multiple particles' wavefunctions. This can lead to different outcomes and behaviors in quantum systems.
  • Quantum Physics
  • Quantum Physics
