Wavefunction really like a wave?
In summary, the conversation discusses the nature of wavefunctions and their resemblance to water waves. It is questioned whether the Schrodinger equation produces a 3D sine wave when plotted. It is also discussed how a photon appears as a single spot when passing through a single slit, and how the presence of a detector can affect the interference pattern. The uncertainty in momentum and position of the particle is also mentioned in relation to interference effects.
venton
36
Is the wavefunction of a particle really shaped like a wave? A lot of analogies are made about how the wave function is like a water wave which can interfere with other waves.
But does the schrodinger equation truly produce something shaped like a wave (ie a 3d sine wave) when plotted?
Particle localized in a finite box gives 3d sine waves.
Thanks. How come that when a photon goes through a single slit that the wavefunction doesn't spread out, and the particle appears randomly anywhere along the spread out wave?
Instead it appears to go through the slit as a particle and appears as single spot.
I am imagining there is literally one slit here, not two.
Whether there is a single open slit or a double-slit setup, there will be an interference pattern due to a single particle (e.g. photon) as long as the setup has no detector to find out where the particle is until the end of the experiment. For the single slit case, if you measure the position of the particle the waveform describing it is changed such that the diffractive interference effects are diminished. The resulting uncertainty in the momentum means there is a spread in the possible ending position of the particle...just that it'll look more like a lump rather than and inferference pattern. Going the other way, the less precisely we detemine the position of the particle passing through the slit, the greater the resulting diffractive interference effects.
FAQ: Wavefunction really like a wave?
What is a wavefunction?
A wavefunction is a mathematical description of a quantum system. It represents the probability of finding a particle in a certain location or state.
How is a wavefunction related to waves?
A wavefunction is similar to a wave in that it exhibits properties such as frequency, wavelength, and amplitude. However, it is not a physical wave like a sound wave or water wave.
Can a wavefunction be visualized?
No, a wavefunction is a mathematical concept and cannot be directly visualized. However, it can be represented graphically as a probability distribution, which shows the likelihood of finding a particle in a certain location.
Is a wavefunction always in the form of a wave?
No, a wavefunction can take on various forms depending on the quantum system it is describing. It can also be in the form of a particle or a combination of both.
How is a wavefunction used in quantum mechanics?
A wavefunction is a fundamental concept in quantum mechanics and is used to calculate the behavior of particles at the microscopic level. It is used to determine the probability of outcomes in experiments and predict the behavior of quantum systems.
