Wavelength limits of Planck's Law
In summary, Planck's radiation law for blackbody radiation used energy quanta to explain experimental data, while Wien's law and the Rayleigh-Jeans law used classical physics and were accurate for different ends of the spectrum. Both equations can be derived from Planck's law by applying a wavelength limit, but the confusing part is that Wien's law is derived from a continuous energy spectrum while the Rayleigh-Jeans law is derived from energy quantization. This raises the question of whether there is any physical significance to the fact that the Rayleigh-Jeans law follows from an increase in energy quantization in Planck's formula.
Math Jeans
349
As is well known, Planck's radiation law for the distribution function of blackbody radiation used a then new concept of energy quanta in order to describe experimental data.
The distribution functions formulated by Wilhelm Wien and Lord Rayleigh, describing the same phenomena, were formulated from classical physics, and were accurate when describing opposite ends of the spectrum.
Mainly, Wien's law was accurate for low wavelengths, while the Rayleigh-Jeans law was for long wavelengths.
Similarly, both equations are easily obtained through applying a high or low wavelength limit to Planck's law, but here is the confusing part:
Wien's law was obviously derived through the use of a continuous energy spectrum (no quantization), and it follows that removal of such quantization would therefore yield Wien's law from Planck's law. In other words, if the value of Planck's constant approaches 0, the equation approximates Wien's law just as in the case of a short wavelength limit.
It is also the case that the Rayleigh-Jeans law failed in its use of the equipartition theorem in order to describe energy levels of each mode in the cavity. Upon applying energy quantization to his model, the final equation becomes Planck's radiation law (I have the math for this if it is necessary for discussion).
Here is my question: although use of energy quanta as opposed to equipartition in Lord Rayleigh's derivation will result in a correct final answer, and that Rayleigh himself admits to equipartition's failure at short wavelengths, is there any physical significance to the fact that if no wavelength limit is taken to Planck's formula, the Rayleigh-Jeans law follows from an increase in the magnitude of energy quantization (high limit of Planck's constant)?
I found this quite counter-intuitive.
Didn't Planck still think light was continuous at that time , could you possibly re-phrase your question in a more concise manner .
It isn't a timeline question...it's more of a relation question in that Wien's law follows through removal of discrete energy units, while the lack of a wavelength limit results in the Rayleigh-Jeans law for larger units.
Related to Wavelength limits of Planck's Law
1. What is Planck's Law and why is it important in science?
Planck's Law, also known as the Planck radiation law, is a fundamental law in physics that describes the relationship between the wavelength of electromagnetic radiation and its intensity at a given temperature. It is important in science because it provides a theoretical basis for understanding the emission and absorption of electromagnetic radiation, and plays a crucial role in fields such as astrophysics, cosmology, and quantum mechanics.
2. What is the wavelength range of Planck's Law?
The wavelength range of Planck's Law is theoretically infinite, as it describes the relationship between wavelength and intensity for all electromagnetic radiation. However, in practical applications, it is typically used to describe wavelengths in the range of infrared to ultraviolet radiation, which is the range most relevant to human vision and many scientific studies.
3. Are there any limitations to Planck's Law?
While Planck's Law is a very accurate and widely used theory, there are some limitations to its applicability. It assumes that the emitting or absorbing body is in thermal equilibrium, meaning it is at a constant temperature. It also does not take into account certain phenomena such as stimulated emission, which are important in some applications of electromagnetic radiation.
4. How does Planck's Law relate to blackbody radiation?
Planck's Law is often used to describe blackbody radiation, which is the theoretical radiation emitted by a perfect absorber and emitter of radiation at a given temperature. This means that the intensity and wavelength distribution of blackbody radiation can be described by Planck's Law.
5. Can Planck's Law be used to calculate the wavelength of a specific type of electromagnetic radiation?
Yes, Planck's Law can be used to calculate the peak wavelength of a specific type of electromagnetic radiation emitted by a body at a given temperature. This is known as the Wien displacement law and is given by the equation λ_max = b/T, where λ_max is the peak wavelength, b is a constant, and T is the temperature in Kelvin.
  • Other Physics Topics
  • Quantum Physics
  • Quantum Physics
