Wavelength, temperature in transition
In summary, the conversation is about someone needing help with three problems related to physics and calculations involving energy levels, radiation, and temperature.
akance
Hi! I really need some help
I'm really really not good at physics...so
Here it is
1) The electron energy of a hydrogen atom is given by -C/n^2 relative to zero energy at infinite separation between the electron and the proton (n is the principle quantum number, and C is a constant). For detection of the n=2 -> n=3 transition(656.3 nm in the Balmer Series), the electron is the ground state of the hydrogen atom needs to be excited first to the n=2 state. Calculate the wavelength (in nm) of the absorption line in the starlight corresponding to the n=1 -> n=2 transition.
2) According to Wien's law, the wavelength corresponding to the maximum light intensity emited from a blackbody at temperature T is given by (wavelength)(Temperature) = 2.9 mmK
Calculate the surface temperature of a star whose blackbody radiation has a peak intensity corresponding to the n=1 -> n=2 excitation of hydrogen
3) The ground state of hydrogen is split into two hyperfine levels due to the interaction between the magnetic moment of the proton and that of the electron. In 1951, Purcell discovered a spectral line at 1420 MHz due to the hyperfine transition of hydrogen in interstellar space. Hydrogen in interstellar space cannot be excited electronically by starlight. However, the cosmic background radiation, equivalent to 2.7K, can cause the hyperfine transition. Calculate the temperature of a blackbody whose peak intensity corresponds to the 1420 MHz transition
Can you please! help me with these 3 problems...! I am so confused!
Here it is
How much of these problems can you do?
1) The wavelength of the absorption line corresponding to the n=1 -> n=2 transition can be calculated using the Rydberg formula: 1/λ = R(1/n1^2 - 1/n2^2), where R is the Rydberg constant (1.0974x10^7 m^-1), n1=1 and n2=2. Plugging in these values, we get: 1/λ = 1.0974x10^7 (1 - 1/4) = 0.8228x10^7 m^-1. Converting this to nm, we get a wavelength of 121.6 nm.
2) Using the given equation, we can rearrange to solve for the temperature: T = (wavelength)/(2.9 mmK). Plugging in the wavelength from part 1 (121.6 nm), we get a temperature of approximately 4181 K.
3) To calculate the temperature of the blackbody corresponding to the 1420 MHz transition, we can use the formula: T = (wavelength)/(2.9 mmK). The wavelength in this case is given in MHz, so we need to convert it to meters first. 1420 MHz is equivalent to 2.11x10^-4 m. Plugging this into the formula, we get a temperature of approximately 7.28 K. This is very close to the temperature of the cosmic background radiation, which is expected since this is the temperature that can cause the hyperfine transition.
1) The energy difference between the n=1 and n=2 states can be calculated using the formula -C(1/nf^2 - 1/ni^2), where nf=3 and ni=2. This gives us an energy difference of -C(1/9 - 1/4) = -3C/36 = -C/12. To excite the electron from the n=1 state to the n=2 state, this energy difference must be supplied by the incoming starlight. We can use the formula E=hc/λ, where E is the energy, h is Planck's constant, c is the speed of light, and λ is the wavelength. Setting E equal to -C/12 and solving for λ, we get a wavelength of 121.6 nm.
2) Using Wien's law, we can set the wavelength equal to 656.3 nm (corresponding to the n=1 -> n=2 transition) and solve for the temperature T. This gives us T= 2.9 mmK/656.3 nm = 4422 K.
3) The energy difference between the two hyperfine levels is given by E=hf, where h is Planck's constant and f is the frequency of the spectral line. We can rearrange this equation to solve for f, which gives us f=E/h. Plugging in the energy difference between the two hyperfine levels (1420 MHz) and Planck's constant, we get f= -C/12h. To find the temperature corresponding to this frequency, we can use Wien's law again, setting the wavelength equal to the transition frequency (1420 MHz) and solving for T. This gives us T= 2.9 mmK / 1420 MHz = 2.04 K.
Related to Wavelength, temperature in transition
What is the relationship between wavelength and temperature in transition?
The relationship between wavelength and temperature in transition is described by Wien's displacement law, which states that as the temperature of an object increases, the wavelength at which it emits the most radiation decreases.
Why does the temperature of an object affect its wavelength in transition?
The temperature of an object affects its wavelength in transition because as the temperature increases, the atoms and molecules within the object vibrate more vigorously, causing them to emit shorter wavelengths of light.
How does the wavelength of light emitted during a transition correspond to the temperature of an object?
The wavelength of light emitted during a transition corresponds to the temperature of an object through Wien's displacement law, which states that objects with higher temperatures emit shorter wavelengths of light.
Can the wavelength of light emitted during a transition be used to determine the temperature of an object?
Yes, the wavelength of light emitted during a transition can be used to determine the temperature of an object. This is because Wien's displacement law allows us to calculate the temperature of an object based on the peak wavelength of its emitted radiation.
How does the temperature in transition of an object vary with its chemical composition?
The temperature in transition of an object can vary with its chemical composition because different elements and molecules have different characteristic energy levels and transitions. Therefore, the wavelengths of light they emit during transitions can vary, leading to differences in temperature based on chemical composition.
  • Atomic and Condensed Matter
