Are the Peaks and Troughs of a Wave Always the Same Size?
  • Thread starter Bashyboy
In summary, the size of peaks and troughs in a wave is always the same for ideal plane waves, while for real waves in a medium, it depends on factors such as diffraction and refraction. The measurement of wavelength as the distance between two points forming a phase also depends on the constraints of the waves.
Bashyboy
1,421
Hi,
I was wondering a peak and its proceeding trough in a wave were always the same size?
Thanks
This really depends on whether you are talking about (ideal) plane waves or real waves in a medium.
Plane waves, e.g., y = A cos(kx - wt), are exactly periodic by definition, so the peaks and troughs are identical, unchanging, and exactly symmetrical around '0' (although you can shift the entire wave up or down by adding a constant, or 'DC', offset).
Wavelength
Hi,
Is it possible to describe a wavelength as the distance between two points and the on a wave, that forms a phase?
Bashyboy said:
Hi,
Thanks
Bashyboy said:
Hi,
(two similar threads merged)
As Oliver says, the answers to both of your questions depends on how you constrain the "waves".
If you are talking about continuous traveling sine waves that do not vary in amplitude, wavelength or phase, then yes, the measurements are straightforward.
But if there are things that can distort the waves, like diffraction, refraction, medium changes (like changing water depth for water waves), then some of these measurements are harder to make and define.
Okay, thank you both very much: I understand now.
FAQ: Are the Peaks and Troughs of a Wave Always the Same Size?
1. What are peaks and troughs in a wave?
Peaks and troughs refer to the highest and lowest points of a wave, respectively. They can be seen as the crests and troughs of a wave on a graph.
2. How are peaks and troughs related to wavelength?
Peaks and troughs are directly related to the wavelength of a wave. The distance between two consecutive peaks or troughs is equal to one wavelength.
3. Can different waves have the same number of peaks and troughs?
Yes, waves can have the same number of peaks and troughs but still have different characteristics. For example, a high frequency wave will have more peaks and troughs in a given time period compared to a low frequency wave.
4. What is the difference between amplitude and peak/trough?
Amplitude refers to the maximum displacement of a wave from its resting position, while peaks and troughs refer to the highest and lowest points of a wave on a graph. Amplitude is a measurement, while peaks and troughs are visual representations of a wave.
5. How do peaks and troughs affect the energy of a wave?
The height of the peaks and depth of the troughs in a wave are directly proportional to the energy of the wave. Higher peaks and deeper troughs indicate a greater amount of energy in the wave.
