Way to generalize the relationship between T and T^2?
In summary, the conversation discusses the relationship between diagonalizable matrices and their powers, specifically T and T^2. It is mentioned that if T is diagonalizable, then so is T^2, but the reverse implication is not always true. A counterexample is provided to demonstrate this. It is also mentioned that the addition of two diagonalizable matrices may not always be diagonalizable, and a counterexample is suggested. The conversation concludes with a question about the diagonalizability of a specific 2x2 matrix.
mind0nmath
Hey,
I know that if T(linear transformation in finite dim-vector space) is diagonalizable, then the matrix A that represent T is diagonalizable if there exist a matrix P=! 0 that is invertible and A=P^-1 * D * P for a diagonal matrix D.
I also know that raising A to a positive power will equal the right side with D raised to that same power. i.e. A^n = P^-1 * D^n * P
Does this imply that if T is diagonalizable so is T^2? what if T^2 is diagonalizable, then does that imply T is diagonalizable?
I think that it is an iff statement. Can anyone shine some light into this situation? maybe a counter example? is there a way to generalize the relationship between T and T^2?
T diagonalizable certainly means T^2 is diagonalizable. The reverse implication is false, in general. To see why: if t is an e-value of T, then t^2 is an e-value of T^2. Now, what if s is an e-value of T^2? We're surely going to want sqrt(s) an e-value of T, but what if the matrices are over R and s=-1?
So if T is over the complex numbers, then both directions are true?
i.e. T is diagonalizable <=> T^2 is diagonalizable?
no. the standard example of a on diagonalizable matrix is a nilpotent matrix. so if T^2 = 0, then T^2 is obviously diagonal but T may not be.
e.g. differentiation of linear functions is square nilpotent, but there are no linear functions such that Df = af except f =0.
I thought for T to be diagonalizable, it should have dimT distinct eigenvalues or dim(T) linearly independent eigenvectors. Then how is the Zero matrix diagonalizable? aren't the roots all the same(i.e. =0)? and null(T)=C^n?
It is diagonalizable by your own criteria: any basis is a set of linearly independent eigenvalues.
How about the addition of two diagonalizable matricies? Is it always diagonalizable in some basis if the field is the complex numbers?
my initial thought is: yes. by the spectral theorem. but not 100% sure since I suspect we might not be able to find a basis for the addition of the matrices which in turn would make it diagonalizable.
any thoughts??
Have you attempted to find a counterexample? Keep in mind that a nonzero nilpotent matrix is not diagonalizable.
Here's a new question(related to the subject). Is the 2x2 matrix with only a scalar in the right upper corner and all other entries = 0, diagonalizable? That matrix, call it T, is nilpotent. T^2 is the zero matrix. Isn't the zero matrix diagonalizable? it is in the diagonal form so it must be. Is T diagonalizable??
If the scalar in the upper right corner is nonzero, then no, this matrix is not diagonalizable. It's been pointed out twice in this thread that a nonzero nilpotent matrix is not diagonalizable (general nxn matrices even, not just 2x2s) -- try to prove this.
FAQ: Way to generalize the relationship between T and T^2?
What is the relationship between T and T^2?
The relationship between T and T^2 is that T^2 is the square of T. In other words, T^2 is equal to T multiplied by itself.
Is the relationship between T and T^2 always true?
Yes, the relationship between T and T^2 is always true because it is a mathematical rule that applies to all numbers.
How can the relationship between T and T^2 be generalized?
The relationship between T and T^2 can be generalized by stating that for any number T, T^2 is equal to T multiplied by itself.
Is the relationship between T and T^2 important in science?
Yes, the relationship between T and T^2 is important in science as it is a fundamental concept in mathematics, which is the foundation of many scientific principles and theories.
Can the relationship between T and T^2 be applied to other variables?
Yes, the relationship between T and T^2 can be applied to other variables as long as they follow the same mathematical rule. For example, the relationship between S and S^2 would also be the square of S.
