- #36
rcgldr
- 8,876
- 638
rcgldr said:The only dissension here is whether gyroscopic reactions help or hurt self-stability (defined as a tendency to return to a vertical orientation).
My concern is that gryoscopic reactions are sometimes described as correcting factors as opposed to dampening factors.A.T. said:A better definition of self-stability is "a tendency to return to a vertical orientation, an stay there, not oscillate around it." That is the point of "damping", or the derivative term in control theory: preventing over-correction and oscillation around the optimum.
The caster aspect of trail is a dampening factor, and increasing trail can reduce or eliminate speed wobble. In the case of motorcycles, this was done on the Honda CBR900RR (1990's) which increased trail by reducing the triple clamp offset used on the early versions of that bike, initially an aftermarke part before Honda made the same change in later versions. Early radio control motorcycles used a lot of trail (like fork tubes located behind the pivot axis), but the newer ones rely more on gyros and/or active control.
Other dampening methods called steering dampers are used on some motorcycles. These can be friction oriented, small shocks linked to frame and triple clamp, or electronically controlled.
The test bikes made with counter rotating wheels don't seem to have an oscillation problem with self stability, but the test speeds may not have been fast enough to result in speed wobble.
I'd like to see an actual two skate bike gliding on ice to show that gryoscopic reactions are not required for correcting or dampening lean angle.
Speed wobble can also be caused by too much flex in the frame and/or swing arm. I don't know if trail and/or steering dampers can compensate for this.
