Weak coupling strength constant
In summary, the weak coupling strength constant, also known as the weak interaction constant, is a fundamental physical constant that describes the strength of the weak nuclear force. It is typically measured through experiments involving beta decay and muon decay, and its numerical value is approximately 1/137 or 0.0073. Compared to other fundamental constants, such as the electromagnetic and strong coupling constants, the weak coupling strength constant is significantly weaker and is only observed at the subatomic level. While it is believed to be a constant over time, some theories suggest it may vary at extremely high energies, but there is currently no experimental evidence to support this idea.
neelakash
511
When it is said that the relative strength of weak interaction is [tex]\ 10^{-5}[/tex],what does this mean?
On calculation I am getting [tex]\alpha_w=\10^{-3}[/tex] with [tex]\ G_F=\ 1.16\times\ 10^{-5} \ GeV^{-2}[/tex]
I had an impression that [tex]\alpha_w[/tex] should be [tex]\ 10^{-5}[/tex].Which one is correct?
"relative strength" is not a very well-defined concept. The ratio of weak to electromagnetic interaction strengths depends a lot on the energy scale.
The relative strength of weak interaction being \ 10^{-5} means that it is 10,000 times weaker than the strong interaction, which has a relative strength of about 1. This value is represented by the weak coupling constant, denoted by \alpha_w, which is a dimensionless quantity that describes the strength of the weak interaction.
In your calculation, you have correctly determined the value of \alpha_w to be approximately 10^{-3}, which is consistent with the experimental value. The confusion may arise from the fact that the value of the Fermi constant, denoted by G_F, is also often used to describe the strength of the weak interaction. However, G_F has units of energy squared, which is why it is expressed in terms of GeV^{-2}.
So, to clarify, both \alpha_w and G_F describe the strength of the weak interaction, but they are two different quantities with different units. The value of \alpha_w being 10^{-3} is correct, while the value of G_F being 1.16\times\ 10^{-5} \ GeV^{-2} is also correct. I hope this clears up any confusion.
Related to Weak coupling strength constant
1. What is the weak coupling strength constant?
The weak coupling strength constant, also known as the weak interaction constant, is a fundamental physical constant that describes the strength of the weak nuclear force.
2. How is the weak coupling strength constant measured?
The weak coupling strength constant is typically measured through experiments involving beta decay and muon decay. These processes involve the weak nuclear force and can provide information about its strength.
3. What is the numerical value of the weak coupling strength constant?
The numerical value of the weak coupling strength constant is approximately 1/137, or 0.0073. This value is much smaller than the values of other fundamental constants, such as the electromagnetic coupling constant or the strong coupling constant.
4. How does the weak coupling strength constant compare to other fundamental constants?
The weak coupling strength constant is significantly weaker than the other fundamental forces, such as electromagnetism and the strong nuclear force. This is why the effects of the weak force are only seen at the subatomic level.
5. Can the weak coupling strength constant change over time?
The weak coupling strength constant is believed to be a fundamental constant that remains constant over time. However, some theories, such as Grand Unified Theories, suggest that it may vary at extremely high energies. Currently, there is no experimental evidence to support this idea.
