Weak Duality Theorem (according to my course notes)
In summary, the theorem asserts that if x is feasible for P and y is feasible for D, then cx ≤ by. This theorem is a logical consequence of the fact that if P and D are both feasible, there exists an x which is feasible for P and y which is feasible for D. However, this theorem does not require a formal proof, since it is just a logical consequence of the theorem.
Jamin2112
986
Weak Duality Theorem. If x ε ℝn is feasible for P and x ε ℝm is feasible for D, then
cTx ≤ yTAx ≤ bTy.
Thus, if P is unbounded, then D is necessarily infeasible, and if D is unbounded, then P is necessarily infeasible. Moreover, if cTx = bTy with x feasible for P and y feasible for D, then x must solve for P and y must solve for D.
c ε ℝn, b ε ℝm A ε ℝm x n
P: maximize cTx subject to Ax ≤ b, 0 ≤ x, where the inequalities Ax ≤ b are to be interpreted componentwise.
D: minimize bTy subject to ATy ≥ c, y ≥ 0.
So the "proof" that follows in my course notes starts with
Let x ε ℝn be feasible for P and y ε ℝm be feasible for D.
Then it basically gives a simple verification of the inequality and says that the other results obviously follow.
I'm confused by the logic here. The theorem starts by choosing x and y feasible for P and D. Then it states that if P is unbounded, the inequality shows that there could be no feasible y ...... which is strange because the inequality only works for a feasible x and y.Could someone clear this up for me?
The hypothesis for the theorem asserts that there exist x which is feasible for P and there exists y which is feasible for D. By that hypothesis, it is impossible for either P or D to be infeasible.
Can that be gathered from looking at the inequality? My point is that the inequality is only relevant for feasible x and y; hence I don't see how it illustrates a point about the infeasibility of y.
From my course notes:
Look at what the Theorem says: it says IF x is feasible for P and y is feasible for D, then cx ≤ by. OK, so think about it: if P is unbounded, there cannot be any y that is feasible for D (because a feasible y produces an upper bound on cx for all feasible x). Similarly for the other part of the statement.
BTW: it is possible for both P and D to be infeasible, as some examples show.
RGV
RGV
Here's the logic of the first part of the theorem.
Premises:
(1) Ax ≤ b
(2) ATy ≤ c
Logical Consequence:
cTx ≤ bTy.
Here's the logic of the second part of the theorem:
Premises:
(1) For all M ε ℝ there exists an x ε ℝn such that cTx > M.
There exists no y ε ℝm such that ATy ≤ b.
Those seem like unrelated parts of the theorem, each requiring it's own proof. Maybe I'll need to look at it more closely.
The second part is not part of the main theorem, but is a sole consequence of the theorem. It does not really need a formal proof, since it is just a logical consequence of the theorem itself. The theorem implies that IF P and are both feasible, we have an upper bound on cx and a lower bound on by. Thus, if it happens that cx is unbounded it MUST be the case that D is i feasible (for when we sat that cx is unbounded we are implicitly assuming that P is feasible).
RGV
Related to Weak Duality Theorem (according to my course notes)
1. What is the Weak Duality Theorem?
The Weak Duality Theorem is a fundamental concept in mathematical optimization that states that the objective function of the dual problem provides a lower bound for the optimal value of the original problem.
2. How is the Weak Duality Theorem used in optimization problems?
In optimization problems, the Weak Duality Theorem is used to provide a lower bound for the optimal value of the original problem. This lower bound can then be used to evaluate the feasibility of a solution or to guide the search for an optimal solution.
3. What is the key assumption of the Weak Duality Theorem?
The Weak Duality Theorem assumes that the original problem and its dual problem are both feasible and have a finite optimal value. It also assumes that the objective functions are continuous and the constraints are convex.
4. Can the Weak Duality Theorem be used to determine the optimal solution?
No, the Weak Duality Theorem only provides a lower bound for the optimal value of the original problem. It cannot be used to determine the exact optimal solution.
5. Is the Weak Duality Theorem always applicable?
No, the Weak Duality Theorem is applicable only to certain types of optimization problems, such as linear programming problems. It may not hold for non-linear or non-convex problems.
  • Classical Physics
  • Calculus
  • Topology and Analysis
