I Weak principle of equivalence (Galileo, Newton)
The discussion centers on the weak principle of equivalence and whether gravitational force equals inertial force during free fall. It highlights that gravitational mass and inertial mass are equivalent, leading to the conclusion that in free fall, gravitational acceleration equals inertial acceleration. The concept of inertia is clarified as not being a force but a property of mass that describes resistance to acceleration. The conversation emphasizes that Newton's second law (F=ma) applies strictly within inertial frames, while inertial forces arise only in non-inertial frames. Ultimately, the complexities of these concepts point to the need for a deeper understanding of gravity as explained by General Relativity.
qnt200
TL;DR Summary
Does the force of inertia act on the body during free fall, according to the weak principle of equivalence (Galileo, Newton)?
Many tutorials that explain the weak principle of equivalence (Galileo, Newton) do not clearly state whether the body is affected by the force of inertia during free fall as a result of the gravitational acceleration of the body. In other words, the question is whether, during the free fall of a body in a gravitational field, gravitational force equals inertial force (Fg=Fi).
Is this incompatible with the concept of two masses (gravity and inertial mass)? What is GR's opinion on it?
There is mass, gravitational and inertial. Inertia is another name for inertial mass.
Inertia is not a force.
Likes malawi_glenn and qnt200
Thank you for explaining. It raises a few more questions for me about the logic of bodies in free-fall:
It is known that gravitational mass = inertial mass (established with enormous precision). That is why we can talk about only one mass. Therefore m = mg = mi. In free fall, mg = ma, i.e., g = a. The product of ma acts as inertia on the body, slowing it down during free fall so that it does not instantly reach the speed of light.
I think it is irrelevant whether the product of mass and acceleration is called a force.
I don't know how correct this attitude is?
This doesn’t make sense. Inertial forces are not a result of acceleration. Inertial forces are a result of using a non-inertial reference frame. Sometimes non-inertial frames are called accelerating frames, but an accelerating frame is a different concept than acceleration.
If you want to ask about inertial forces then you must specify the non-inertial reference frame you are using.
Likes protonsarecool and qnt200
It is difficult to follow what you are saying here. It seems to indicate that you are understanding things incorrectly (or at least not in the standard way).
Apparently you have this idea that if we exert a force on an object then, were it not for the object's inertia, that object would fly away at the speed of light. That is a somewhat reasonable intuition.
To be picky, if we stay within the Newtonian framework, there is nothing special about the speed of light. A massless object subject to a finite force would be pushed away with an undefined speed. We might think of that speed as infinite, but from a mathematician's point of view, "undefined" is more correct. A mathematically inclined physicist would likely say that you cannot exert a finite force on a massless object.
But never mind that. Set the speed of light to one side.
You want to rescue us from having the object move off at an undefined velocity by conjuring up a counter-force called the "force of inertia". So we have this original real force f=ma pushing the object away and this magical counter-force pushing back. But hold on a minute... if we have equal and opposite forces then the object should not move at all. Eppur si muove.
We see real objects subject to real forces move all the time. So this way of thinking about the "force of inertia" cannot be entirely correct.
The standard way of thinking about this is to stick to inertial frames. You have an interaction force ##f## and an object of mass ##m## moves off with an acceleration ##a## when acted upon by that force. End of story.
We do not wave our hands and conjure up a force to explain the resulting motion. We already have the original force ##f## that explains the motion and a law of motion (##f=ma##) that quantifies the result. There is no need for anything more. The property that we call "inertia" is already encapsulated in Newton's second law.One can rescue the idea of an "inertial force" associated with an object's mass by adopting a non-inertial frame. But others such as @Dale are happily explaining that part.
Likes qnt200, Dale and PeroK
Dale, jbriggs444
Thank you for your interesting answers and guidelines indicating to me the scope of classical physics, i.e., the inertial frame of reference. F=ma is only valid in inertial frames of reference. It is actually clear to me that the full answers, especially regarding gravity, are found within GR.In addition to other things, you pointed out a very interesting question that I have been thinking about for a long time:
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
