- #36
dcb
- 14
- 1
I now understand your argument about the scale. It seemed to me like the scale is designed to only measure Y forces but I got inconsistent results in an experiment. Intuitively it seems like the X forces are 0 at 0 degrees reach a maximum at 45 and go back to 0 at 90 (at least for H=0).
I grabbed a 2x8 sitting around in the garage and a device measures angles by using gravity to point a needle straight up. I put double sided tape on the scale so the 2x8 wouldn't slip. The 2x8 had some knots in it so the weight distribution was likely not perfectly uniform.
So as to not bias the experiment I did the scale measurements first. I measured the bottom left edge of the 2x8 at 20 degrees and 45 degrees and got 785 grams and 1160 grams. I used my finger at the bottom right edge to push it up. I pretty much kept the force on my finger perpendicular to the H edge.
I then measured the length to be 452 mm and the height to be 184 mm and the board weighed 1368 grams.
When I did the math I got 787 grams at 20 degrees which is pretty close. At 45 degrees I got 962 grams so the scale is measuring some X force at least at the worst angle.
When I get time I'll build form a nail out of some tubular metal at the right height for 45 degrees (plus the scale height), put it under the right edge and redo the experiment.
