Weight lifter - Acceleration of the barbell ?
In summary, a weight lifter who has a mass of 90.0 kg is performing a lift exercise, lifting a barbell weight of 490N (50kg) a distance of 0.60 m in 1.6 seconds. The barbell has a constant upward acceleration and the athlete has no acceleration as he lifts the weight. The forces acting on the barbell are gravity (Fg) and applied force (Fa), while the forces acting on the athlete are gravity (Fg), normal force (Fn), and applied force (Fa). According to Newton's 3rd Law, for every action (force), there is an equal and opposite reaction (force). The net force exerted on the barbell is
nukeman
655
Weight lifter - Acceleration of the barbell ??
Here is the info, and below are the questions I am a little stuck on...
"An athlese who mass is 90.0 kg is performing a lift exercise. Starting from the rest position, he vertically lifts a barbell weight that weighs 490N (50kg). He lifts the barbell a distance of 0.60 m in 1.6 seconds. Assume that the barbell has a constant upward acceleration and the athlete has no accerlation as he lifts the weight.
1) How would I draw a FBD for the barbell and the athlete? Which forces are acting on each the barbell and athlete?
2) Find the force that the athlete applies to the barbell to accerlate it?
3) Find the total force that the athlete's feet exert on the ground as he lifts the barbell?
For the FBD on the barbell - Would it just be gravity(Fg) and applied(Fa) force pulling the weight up?
Not sure how to make a FBD for the athlete?
Would it just be applied force?
Really stuck on this one!
FBD for the athlete:
What are the forces acting on the athlete?
Hi Sammy!
Well I would think Fg(gravity) downwards.
and Fn(normal force) from the floor upwards?
Is that it? Would the weights be an applied force?
P.S. - Am i correct for the FBD forces on the barbell?
Does the athlete exert force on the barbell ?
Then what does Newton's 3rd Law say about the barbell exerting force on the athlete?
Yes, the athlete exerts a force on the barbell...For every action, there is a positive and equal reaction. ?
So on the barbell there is only Fg and Fa forces?
And on the person, there is Fg, Fnormal, and Fapplied?
For every action (force) there is an equal (in magnitude) and opposite (in direction) reaction (force).
I repeat, "Then what does Newton's 3rd Law say about the barbell exerting force on the athlete? "
So your saying the barbell is exerting an equal in magnitude, and opposite reaction in direction?
Yes.
(And Newton says the same thing.)
SammyS said:
Yes.
would that force be an applied force?
Any chance u can help with other questions?
"Find the force that the athlete applies to the barbell to accerlate it?"
What's the net force exerted on the barbell if it accelerates as described?
By Netforce, do you mean mass*acceleration?
So, mass of 90.0 kg * acceleration of .375 m/s correct?
so 33.75 ? ?
Acceleration is incorrect. also incorrect units.
Added in Edit:
The barbell accelerates uniformly. It travels 0.6 m in 1.6 s for an average velocity of 0.375 m/s. But since it starts from rest (zero velocity), its final velocity is 0.75 m/s, which gives the correct average velocity.
So the barbell's velocity changes by 0.75 m/s in a time of 1.6 s. What's its acceleration during that time?
Added in Edit:
So the acceleration would be 0.468 m/s^2 ?
0.46875 m/s2
FAQ: Weight lifter - Acceleration of the barbell ?
1. What is the acceleration of the barbell during a weightlifting exercise?
The acceleration of the barbell during a weightlifting exercise depends on several factors, such as the weight of the barbell, the force applied by the lifter, and the speed at which the barbell is lifted. However, on average, the acceleration of the barbell can range from 1-2 meters per second squared.
2. How does the acceleration of the barbell affect the difficulty of the lift?
The acceleration of the barbell can greatly impact the difficulty of the lift. A higher acceleration means the barbell will move faster and require more force from the lifter to control and lift it. This can make the lift more challenging and require more strength and technique.
3. Can the acceleration of the barbell be increased?
Yes, the acceleration of the barbell can be increased by increasing the force applied by the lifter or by decreasing the weight of the barbell. However, it's important to note that proper form and technique should always be prioritized over increasing acceleration, as it can lead to injury if not done correctly.
4. How does the acceleration of the barbell impact muscle growth and strength gains?
The acceleration of the barbell is an important factor in muscle growth and strength gains. A higher acceleration can lead to more muscle fiber recruitment and activation, which can result in better strength gains. However, it's important to have a balanced training program that incorporates different speeds and intensities to see optimal muscle growth and strength gains.
5. What is the role of gravity in the acceleration of the barbell during weightlifting?
Gravity plays a crucial role in the acceleration of the barbell during weightlifting. As the barbell is lifted against gravity, it creates an opposing force that the lifter must overcome. This creates the acceleration of the barbell and also contributes to the difficulty of the lift. Additionally, gravity also plays a role in the deceleration of the barbell as it is lowered back down, which helps to control the movement and prevent injury.
