njr140
- 2
Hi, I'm a first time poster here and I have a physics question I can't find the answer to anywhere. I don't know much about physics so this might be a basic question to answer.
I have a mass (x) that is attached to a cable that is attached to a counterweight that is at 10 feet that will be dropped to ground level via a pulley at the top. The cable will release x once it reaches the end of the launch track and the object will go vertical with the maxium amount of kinetic energy. The launch would occur horizontally and the object would then go vertical.
X needs to reach a certain height (z) (10 vertical feet). I don't know how fast the mass would be moving; it would depend on the speed of the counterweight dropping freely with gravity.
As of now, I don't need friction or air resistance factored in, just the weight.
The question I have is, if you have a variable mass (x), how much counterweight (y) will you need to launch the object 10 feet (z)?
I have created a GIF to give a visual since it's kind of hard to explain what I mean.
http://s27.postimg.org/ml4madh83/output_xd_Ooc_F.gif
