Weight of object in outer space away from galaxies
In summary: Since the objects are supported in some manner, they would be considered to be in a state of equilibrium. This means that the net gravitational force on either object would be zero.Since the objects are supported in some manner, they would be considered to be in a state of equilibrium.
Entr0py
102
Suppose an object were sent far out in space away from galaxies, stars, or other bodies. How would its weight change?
w=mg where w and g are vectors
Since mass is an intrinsic property and doesn't depend on external sources, then its mass is constant. But its weight would change. Let's say it has a mass m=1 kg. Then its weight on Earth would be 9.8 N. Then since the object is in space away from gravitational influences, wouldn't it be in a state of weightlessness? Because it has nothing to accelerate towards. So would its weight and apparent weight equal 0 N?
Correct.
Thanks
Would that mean that the object is freely falling. I would think not because it has nothing causing it to accelerate towards (like a planet)
It's not free falling. If it were to, it would have an acceleration, which you clearly said it didn't.
So the object is just still in space?
Not moving relative to everything else?
Yes.
No. It is moving as motion is relative. However, it isn't explicitly in free fall. Free fall only occurs when there is gravity or any form of gravitational forces.
Technically there is no place in the known universe that is totally free of gravitational influence, since gravity extends to infinity.
For practical purposes an object can be far enough away from large bodies / gas clouds that it is effectively weightless, but it is never exactly weightless unless all gravitational forces cancel each other out and for a body in intergalactic space I would think that unlikely simply because it's a many-body problem of magnitude pretty much beyond human comprehension.
On the other hand, given the Cosmological Principle, perhaps it's reasonably to assume that forces DO cancel out, but I wouldn't bet on it.
Likes Entr0py
The idea that the object is still in space presupposes that "still" has a meaning in this context. It does not. An object sitting in the middle of nowhere is neither still nor moving unless you specify what it is still or moving relative to.
Space is not something that you can move relative to.
Free fall can include the case of zero gravity. In physics, the term "free fall" means that a body is subject to no outside forces other than gravity.
Would this object be still relative to the very far away objects in space?
But wouldn't this object have ZERO gravitational attraction to anything in space if it is located far enough away that it isn't gravitationally attracted to anything (so an infinite distance away from everything else).
You cannot be "an infinite distance away from every things else". Please reread post #9
Imagine a pair of planets in deep space. Imagine that they are supported in some manner so as to remain a fixed distance apart. Consider a line drawn from the center of one planet to the center of the other. In a region near this line, the component of the net gravitational influence perpendicular to this line always points toward the line. Exactly on the line, the net gravitational force is entirely along the axis of the line.
Consider the gravitational force along the line. At the one end it points toward the one planet. At the other end it points toward the other planet. It varies smoothly along the length of the line. There must be a point somewhere along the line where gravity is exactly zero.
If you factor in the gravitational influence of the rest of the universe, the position where this happens may change. But there will still be such a point.
Even given your rather awkward scenario, I don't agree with the statement I bolded.. Suppose, for example, that the rest of the universe nets out to the equivalent of a small third body off to one side somewhere. Then the net gravitational force isn't even ON the line.
It may be, as I said, that the Cosmological Principle does end up requiring that the net forces from everything cancel out but that is unlikely to happen on a line between two specific bodies.
Gravitational force is not a position. It makes no sense to say that it is or is not on the line.
You have failed to understand the scenario. If the planets are alone in the universe then surely you agree that there will be a point where gravitational force is zero and that this point will be somewhere on the line between the planets, right?
If the gravitational influence of the rest of the universe in the neighborhood of the planets is small, there will still be a path between the two planets where the component of the net force of gravity perpendicular to the axis between the planets is zero. This path may not coincide with the line between the two planets, but it will exist. There will be a point on this path where the gravity is zero.
you're right. What I meant was that the zero point of gravitational attraction was not on the line. Very careless of me. Thanks.
You didn't say they were alone. Yes, if they are alone then I agree but that is not a real-world scenario, it's like a freshman physics problem finding the zero point between the Earth and the moon, ignoring all other forces.
I don't understand the bolded part but as I have said, it is possible that the cosmological principle dictates that the forces would all cancel out; I just don't think so. In the idealized case where the rest of the universe is represented by a single body, then it's a 3-body problem and I agree there is a zero point.
Not the Cosmological Principle. The intermediate value theorem.
Thanks for clearing up my confusion.
How so? Isn't that a rule from calculus?
Yeah, don't get that either.
It is a theorem in real analysis, yes.
Gracias for the reply.
I'm confused by what you mean? By the way, is that a Great Pyrenees in your picture?
I meant that the Great Pyrenees shares your confusion as to why that theorem was brought up in this context.
Likes Entr0py
Ahh, clever way to answer my question.
Apply the theorem three times. For convenience place the two planets in directions labelled "east" and "west". We have a region of space where the vertical component of gravity points downward near the top of the region and points upward near the bottom. Accordingly, there is a surface where the vertical component is zero.
Within this surface, the north/south component of gravity is northward in the southern area and southward in the northern area. Accordingly there is a path where the north/south component is zero.
Within this line, the east/west component of gravity is eastward in the eastern area and westward in the western area. Accordingly there is a point where the east/west component is zero.
Related to Weight of object in outer space away from galaxies
1. What is the weight of an object in outer space away from galaxies?
In outer space, away from any gravitational pull, objects have no weight. This is because weight is a measure of the force of gravity acting on an object, and in the absence of gravity, there is no weight.
2. Does the weight of an object change when it is in outer space away from galaxies?
No, the weight of an object does not change in outer space away from galaxies because weight is dependent on the force of gravity, and in this scenario, there is no gravity acting on the object.
3. Why do objects have no weight in outer space away from galaxies?
Objects have no weight in outer space away from galaxies because weight is a measure of the force of gravity, and in this scenario, there is no gravitational force acting on the object.
4. Is there any factor that can affect the weight of an object in outer space away from galaxies?
No, there are no factors that can affect the weight of an object in outer space away from galaxies. The weight of an object is solely determined by the gravitational force, and in this scenario, there is no gravitational force present.
5. Can an object have weight in outer space away from galaxies?
No, an object cannot have weight in outer space away from galaxies. Weight is a measure of the force of gravity, and in the absence of gravity, there is no weight.
