Rijad Hadzic
- 321
- 20
Two aircraft approaching an aircraft carrier are detected by radar. The first aircraft is at a horizontal distance of 34.3 km in the direction 42 deg north of east. and has altitude 2.4 km
The second aircraft, at altitude 1.2 km, is at horizontal distance of 42.6 km in the direction 37 deg north of east.
What is the distance separating the two aircraft? Hint: use a coordinate system with the x-axis pointing east, the y-axis pointing north, and the z axis in the vertical direction
Ok I really don't understand the hint. it says the z axis in the vertical direction, correct me if I'm wrong but isn't north the vertical direction, which they said make the y axis?
And why do you even need an axis for this problem? Same with the angles.
I used the distance forumla: [itex] ((x_2 - x_1)^2 + (y_2 - y_1)^2 )^{1/2} [/itex]
plugging 42.6 as x_2 and 34.3 as x_1, 1.2 for y_2 and 2.4 for y_1
and got answer 8.38 km.
Book says answer is 9.02 km.
My doubts here are: first off, why would I need to use a 3 dimensional axis?
Second off, I used arc tan to check the angles and they seem off.
For example, on aircraft 1 I did arctan(2.4/34.3) and got 4 degrees, not even close to their stated 42 degrees.
Anyone have any clue? My book is starting to piss me off cause if you've been following the last two questions I asked on here apparently my book was wrong as well, I really want to complain to the author and I question why this was used in an introductory physics course cause I don't feel like I'm learning the material right because of all the contradictions.
Sorry for venting just had to get that off of my chest, and if i am indeed wrong I'm just going to look dumb for complaining lol.
Anyways can anyone please help me.
