What? 2 parallel lines meet at infinity?
In summary, there is no proof that parallel lines meet at infinity in Euclidean geometry. However, this concept can be explored in projective geometry, which is a different form of geometry that allows for parallel lines to meet at infinity. Additionally, the idea of infinity itself is difficult to define and can be subjective depending on one's perspective.
brum
81
anyone know of a proof for this?
here's my best guess...
if you think of "infinity" as an actual "place" (for example, you could say that x is at infinity), then i could kinda see how 2 parallel lines could meet.
if you think of "infinity" as only "approachable" (ie x is approaching infinity, meaning it's just getting bigger and bigger and bigger and bigger) then it doesn't seem reasonable that 2 parallel lines would meet.
in other words, if you think of "infinity" as a PLACE where the rules of geometry n' such are different, then yes, i can kind of see 2 parallel lines meeting.
anyone got a proof / a way of thinking about it?
Mathematics news on Phys.org
Here's my thoughts. Suppose we have y=mx+b for one line and y=mx+c for another. Saying that these two lines meet at infinity is equivalent to saying lim(x-->oo) [(mx+b)-(mx+c)]=0, but we know that the limit is b-c. So I say these two lines will never meet unless b=c.
Also, I've heard you can think of a straight line as a circle of infinite radius. If you have two circles of infinite radius, then they can be considered concentric. If you have two circles which are concentric, they either overlap at all points or at no points. So two parallel line can never meet unless they are originally collinear. I'm not too sure about the second argument, but it sounds decent to me.
(edit: supposing they weren't concentric, they could feasibly intersect at two points, perhaps infinity and negative infinity - in this case, there should be some points in which y1>y2 and some points where y2>y1 - OW! infinity hurts!)
I don't think it is true for Euclidean Geometry. According to the fifth postulate of Euclid's Element, "if a straight line falling on two straight lines makes the interior angles on the same side less than two right angles, the two straight lines, if produced indefinitely, meet on that side on which are the angles less than the two right angles."
Since the interior angles on the same side of 2 parallel lines equal 90 degrees, the lines won't meet even if prodeced to infinity.
You can't give any proof of it- it's not true unless you specifically define infinity so that it is true. And in that case you don't have Euclidean geometry anymore.
Absolutely right. I have had this same debate before.
The form of geometry where this is assumed to be true is projective geometry. It has many beautiful results and is just as "true" as Euclidean geometry ("Of course parallel line meet at infinity - just look down railroad tracks").
lines do not meet at infinity, because infinity is a value, not a location, anyways, infinity does not cannot exsist by any technical purposes, it's just when people decided to stop counting
Infinity isn't a number, nor is it some sort of physical place, it is simply... large... Infinity is difficult to define, it simply means that it is large beyond comprehension.
Infinity means precisely what one defines it to mean; nothing more, nothing less.
ok!
I've been waiting for this. Infinity is a bunny rabbit with blue fur.
Aww, how cute! Can I pet it? :smile:
Please think of an infinitely long carpet (hurkyl the pet in the car is yours).
Will its both sides ever meet ?
Just for fun, you can seduce a geometry off a flat plane onto the surface of a sphere that makes it act like a space with a singular point (my preferred term).
Let S2 be the surface of a sphere with radius 1. That provides the points and curves of the system. Let E2 be a flat two-dimensional plane, like an endless rug that S2 is sitting on. Set up 3D coordinates for the sphere S2 and its rug E2, letting the third coordinate be fixed at value 0 in defining the plane. Let point <0, 0, 0> be the one and only point shared by sphere and plane. The center of the sphere is at <0, 0, 1>, but this is not a point of either space. The top of the sphere (antipode to <0, 0, 0>) is <0, 0, 2>. This is a point of S2.
Here is how we make the special geometry for S2. For any point <x, y, z> of S2, draw a 3D line through <0, 0, 2> and that point <x, y, z>. That line will meet the plane E2 at one point <x', y', 0>. Likewise, for any point <x', y', 0> of E2, draw a line through <0, 0, 2> and <x', y', 0>. That will cross the sphere S2 at one different point <x, y, z> of S2. Therefore, there is a 1-1 mapping that carries points of S2 to points of E2, except for <0, 0, 2>. <0, 0, 2> is our singular point for the coming geometry on S2 and there is no line through it that meets E2 at some point without crossing through the sphere S2. This mapping is called a stereographic mapping of the sphere (minus one point) to the plane. It is invertible.
Here are some coordinate transformation equations for the stereographic mapping function:
mapping points of S2 to points of E2 --
x' = 2x/(2-z)
y' = 2y/(2-z)
z' = 0
(notice that this fails when z = 2, the singular point on the sphere)
mapping points of E2 back to points of S2 --
x = 4x'/(x'2 + y'2 + 4)
y = 4y'/(x'2 + y'2 + 4)
z = 2 - 8/(x'2 + y'2 + 4)
(notice that z is constrained to have a value between 0 and 2, except 2 itself is unallowed. This is because the denominator x'2 + y'2 + 4 is constrained to be value 4 or larger, so 8/(x'2 + y'2 + 4) is constrained to be value 0 to 2. But the only way this last term could have value 0 is if the denominator is not a finite value. Our points <x', y', 0> all have finite coordinates. So z must be 0-or-larger, up to, but NOT including, 2. The top point of the sphere is never reached.)
Alway remember that the points <x, y, z> of S2 are constrained to lie on the unit sphere, so the coordinates must always obey the sphere equation:
(x-0)2 + (y-0)2 + (z-1)2 = 12
. That just boils down to:
x2 + y2 + z2 = 2z
. The <x', y', 0> points are only constrained to have finite-valued coordinates, with z' always equal to 0.
The stereographic mapping allows us to map euclidean curves and figures from S2 to the flat space E2. We look at what the images of these subsets are in the 2D geometry of E2 and attribute these geometric attributes to the originals on S2. So, a straight line on S2 will be something that maps to a euclidean line on E2 and a circle of S2 will be something that maps to a euclidean circle on E2. The same rule holds for line segments, figures, etc. This is the stereographic geometry on S2.
It turns out that the circles of this geometry are those euclidean circles (not only so-called "great circles") on the sphere that do not cross point <0, 0, 2>. Also, the lines of this geometry are those euclidean circles on the sphere that DO cross point <0, 0, 2>. Remember that <0, 0, 2> itself is NOT mapped to anything by the stereographic mapping. This geometry is a non-euclidean geometry, since there are no truly parallel lines (lines always contain point <0, 0, 2>). <0, 0, 2> is the one and only singular point of this space.
Like he said, infinity is not a place or a number...it's just an idea and a mathematical concept of things getting bigger and bigger but i don't think lines would meet at a certain point especially infinity...even the lim a number~~>infinit ( mx+b) this just means a number is getting bigger
FAQ: What? 2 parallel lines meet at infinity?
What is the concept of parallel lines meeting at infinity?
The concept of parallel lines meeting at infinity refers to the idea that two lines that are parallel in our Euclidean space will eventually intersect at a single point if extended to infinity. This point is known as the "point at infinity" or "ideal point".
Is it possible for parallel lines to meet at infinity?
Yes, in the projective geometry, parallel lines are considered to meet at infinity. This concept is different from the Euclidean geometry where parallel lines are defined as lines that do not intersect.
Why do we consider parallel lines meeting at infinity in projective geometry?
In projective geometry, parallel lines meeting at infinity are used to define the cross-ratio, which is an important concept in projective transformations. It also allows us to extend the concept of parallel lines to curved surfaces and non-Euclidean spaces.
Are there any real-world applications of parallel lines meeting at infinity?
Yes, the concept of parallel lines meeting at infinity has various applications in computer graphics, computer vision, and image processing. It is also used in the design of camera lenses and in the study of perspective in art and photography.
Is there a visual representation of parallel lines meeting at infinity?
Yes, there are various visual representations of parallel lines meeting at infinity, including the projective plane and the Poincaré disk model. These representations help us understand the concept of parallel lines meeting at infinity in different geometries.
