What A White Hole Will Look Like?
In summary: Stephen Hawking says, and then it emits something which, as far as we can tell, is sort of random noise with no memory of what went into the black hole. So the white hole emits random junk that looks nothing like the black hole.In summary, a white hole is a hypothetical object that would be the time reverse of a black hole. It is impossible to predict what would come out of a white hole and it would be an independent object, not connected to a "parent" black hole. The white hole would vanish and leave behind something else, making it difficult to identify when looking at one. The concept of an Einstein-Rosen bridge connecting black holes and white holes is not physically reasonable. The formation
Deepblu
63
White Holes may not exist, but if we discover that they are real and we find one, then:
What a white hole will look like?
How it will behave?
What will be its characteristics (such as gravity, mass, size ..etc) in relation with it's parent black hole?
What will be it's effect on nearby stars?
And most important how do we know that we have a white hole when we are looking at one? I was thinking about this and thought because white holes eject photons then maybe from very far they will just look like normal stars.
thanks
Space news on Phys.org
It's impossible to tell in detail, because the whole point of a white hole is that there is no way to predict what will come out of it (and it's impossible for anything to go into it). But a "realistic" white hole (meaning not something that has any significant chance of actually existing, but a model of a white hole that at least allows it to be an independent object) would have whatever was inside (which, as above, there is no way to predict) exploding out of it and causing the hole to vanish, leaving behind either empty space or (highly improbable) some kind of stable object like a star. (This process is basically the time reverse of the idealized Oppenheimer-Snyder model of the gravitational collapse of a stable object to form a black hole.)
There would not be a "parent black hole"; white holes (at least not the kind I was talking about above) are not created from black holes. If they existed, they would be independent objects.
With the white hole model I described above, you wouldn't be able to tell, because, as described above, the white hole would vanish and leave something else behind.
Aren't white wholes connected with black holes by Einstein-Rosen bridge? Where matter goes in a black hole then spewed out via a white hole. How can a white hole form without a black hole on the other end? Or how can a singularity form from nothing to create a white hole?
No. Take a look at the spacetime diagram at the top of this Insights article, which depicts the maximally extended Schwarzschild spacetime in Kruskal coordinates:
https://www.physicsforums.com/insights/schwarzschild-geometry-part-3/
The white hole is region IV, at the bottom; the black hole is region II, at the top. The Einstein-Rosen bridge is a "wormhole" between regions I and III; however, the wormhole pinches off too fast for anything to actually travel between those two regions.
Also note that the black hole is to the future of the white hole (time flows upward in the diagram). So in this diagram, things come out of the white hole and fall into the black hole, not the other way around.
Note, though, that this spacetime is not physically reasonable (for reasons which are explained in the series of four Insights articles of which the one I linked to is the third). So the Einstein-Rosen bridge isn't either.
By not being described by the (not physically reasonable) spacetime described in the article I linked to above. I described a different model (which is still not physically reasonable, but not quite as unreasonable as the one in the article) in my previous posts.
It can't; at least, it seems highly unreasonable. That's a key reason why the spacetime described in the article linked to above is not physically reasonable.
Likes Deepblu and berkeman
The problem is more fundamental than that. A white hole is a time reverse of a black hole. Viewing a white hole would be akin to a mixture of sound waves and heat combining to push a bunch of shattered shards of glass on the floor to form a drinking glass which then hops into your hand.
Take a black hole, and view it with time moving backward. Everything that falls into the black hole you would instead see emitted from the white hole.
Edit: And to point out just how profoundly weird this is, we can add Hawking radiation to the mix. The white hole forms from a burst of high-temperature thermal radiation converging at a point. Over a huge amount of time, the thermal radiation drops in temperature as it streams into the white hole, increasing its mass. Eventually, after trillions upon trillions of years, the white hole starts spitting out light and gas, causing its mass to drop again.
So, yeah, white holes can't exist due to thermodynamics. A white hole means you got the direction of your time coordinate wrong.
A white hole has a singularity in the past. I don't think that you can ask how it formed because that would require GR to describe something "before" the singularity and the whole point is that singularities are where the maths breaks down totally. We can't extend our models past this one - not until we have a working quantum gravity theory, anyway.
Thanks for the insights! It turned out this subject is much more weird that what it looks from the surface!
So a simple conclusion is that white holes are impossible.
Related to What A White Hole Will Look Like?
1. What is a white hole?
A white hole is a hypothetical region of space that is the opposite of a black hole. Instead of pulling matter and light in, a white hole would push matter and light out.
2. How are white holes formed?
White holes are not currently known to exist in the universe, but they are theorized to be formed by the collapse of a black hole in a different universe.
3. What would a white hole look like?
It is difficult to say exactly what a white hole would look like, as they are purely theoretical. Some theories suggest they would appear as a bright, glowing object surrounded by a halo of light. Others propose they would be invisible due to the extreme curvature of space around them.
4. Can we observe a white hole?
As white holes are not currently known to exist, we cannot observe them. However, some scientists believe that white holes may be connected to black holes through a wormhole, which could potentially allow us to indirectly observe them.
5. What would happen if you fell into a white hole?
It is believed that if you were to fall into a white hole, you would be instantly crushed by the intense gravitational forces. This is because the singularity at the center of a white hole would have a repulsive force instead of an attractive one, causing anything that enters to be pushed away with immense force.
  • Cosmology
