Gabriel Maia
- 72
- 1
Hi. I am having some trouble understanding what is the voltage drop in a system with resistors in series.
If there is a difference of electric potential between two points in space, since electric potential is electric potential energy per charge, there is a difference in the electric potential energy between both points, which is to say that there is an electric field there. This electric field will make charges move from one point to the other, right?
Now, if we have a system with a battery and one single resistor, the voltage between both ends of the resistor will be the same provided by the battery. If we add one more resistor, in series with the first one, the voltage between the ends of the series will be the same as for the battery, but the voltage between the endpoints of each individual resistor will be different. Why does the voltage drop little by little from one resistor to the next? This implies that the electric field in the resistors is less strong. What is making it so?
Thank you very much.
