What actually happens when a photon strikes an atom?
In summary, low-energy photons interact with atomic electrons, causing them to be excited and re-emit the photon when they return to normal. This process is similar to how nuclei are bound together using carrier particles. The nucleus plays a role in creating discrete energy levels for the electrons, but differences in shape or spin have minimal effects. High-energy photons, such as gamma rays, can directly interact with the nucleus without involving the electrons.
Decimator
30
I know that when a photon strikes an atom, it excites an electron, which then will re-emit the photon when it returns to normal. But what is actually happening here? Is it really as simple as that, or is there something more fundamental going on here, like how nuclei are bound together using carrier particles?
Low-energy photons interact with the atomic electrons and their energy levels, basically like you described. This usually means visible or near-visible (infrared or ultraviolet). With heavier atoms you can also get this sort of interaction using X-ray photons. The nucleus basically doesn't come into play except in the sense that its attraction of the electrons (inserted into Schrödinger's equation) creates the discrete energy levels. Differences in shape or spin of the nucleus can cause very small effects on the electron energy levels. Look up "fine structure" and "hyperfine structure" in atomic spectra.
High-energy photons such as in gamma rays can interact directly with the nucleus, in which case the electrons are not involved.
FAQ: What actually happens when a photon strikes an atom?
1. What is a photon?
A photon is a basic unit of light, also known as an elementary particle. It carries electromagnetic energy and has no mass or electric charge.
2. What happens when a photon strikes an atom?
When a photon strikes an atom, it can be either absorbed, reflected, or scattered. The specific outcome depends on the energy level and properties of the atom.
3. How does a photon interact with an atom?
A photon interacts with an atom by transferring its energy to the electrons within the atom. This can cause the electrons to jump to higher energy levels or be ejected from the atom entirely.
4. What is the result of a photon being absorbed by an atom?
The result of a photon being absorbed by an atom is that the atom gains energy and its electrons may change energy levels. This is the basis of light absorption, which is used in many scientific fields such as spectroscopy.
5. Can a photon cause a chemical reaction when it strikes an atom?
Yes, a photon can cause a chemical reaction when it strikes an atom. This is because the energy transferred from the photon to the atom can break chemical bonds and create new molecules. This is the basis of photosynthesis, where photons from the sun are used to create chemical energy in plants.
