What actually happens when light meets a surface(QED or QM)?
  • Thread starter Christian Grey
  • Tags
    Light Qm
In summary, when light meets a surface like water or wood, quantum mechanics states that the object's energy level structure determines whether it can accept energy packets from certain ranges of energy, making it either transparent or opaque in those ranges. This range of energy happens to be in the visible spectrum, which is what our human eyes can see. However, in other ranges of energy, such as infrared, the same object may appear transparent or opaque. Quantum electrodynamics explains this by adding vectors to determine reflection or refraction, while Feynman's explanation uses
Christian Grey
23
I want to know what actually happens when light meets a surface like water or wood.
Quantum mechanics says that objects are neither "transparent" nor "opaque". Rather a system as a whole can accept "energy packets" in certain ranges of energy and has no states available to accept other ranges of energy. If something is "transparent" it means its energy level structure (for crystal systems this is called the "band structure") is such that it can't accept energy packets between ~1.7eV to 3.0eV which corresponds to light in the visible spectrum with wavelengths of 700nm (red) to 400nm (violet). There is of course nothing special about that particular energy range except that it happens to be the range that our human eyes have evolved to see. If I instead, for example, looked in the infrared range, like in this image:
http://www.jwst.nasa.gov/exhibit/ir2.jpg
I'd see that the man's eyeglasses are in fact opaque in that range (meaning that the glass does accept energy packets corresponding to the infrared range, even if it didn't in the visual range) and what he's holding there is a "black" garbage bag, which is in fact transparent to that range of light. Here's the same picture in the visual range:
http://www.jwst.nasa.gov/exhibit/ir1.jpg
While quantum electrodynamics says it works on by adding (magnitude only not direction) vectors (from the strange theory of light and matter) you start the stopwatch when photon leaves the light source and you stop the watch when the photon reaches the photo-detector, and then add the two vectors or more to get the resultant vector, which tells whether reflection or refraction will take place.
I am talking about what Feynman discusses about, in the book The strange theory light and matter,when he says that out of 100 photons 4 are partially reflected and 96 are transmitted,and how many photons are refracted or transmitted depends on the thickness of the glass, which he then demonstrates by using stopwatch,he places two photodetectors one above the glass and one below the glass, and starts the stopwatch when the photon moves from the light source and stops it when it has reached either of the photodetectors.
My question is which one is right QM(energy band) or QED(using stopwatch) ?
What actually happens when light meets surface like water, glass or wood? Which is right: QM or QED? Am I missing something in QED that I don't know (because it's called most complete theory of light) or it is best explained by condensed matter physics?
Feynman is about as correct as you can get at the lay level - but you have to take with a bit of a grain of salt when he says you won't have to unlearn anything later.
Beyond that - it gets very very complicated - see the following for what actually happens with absorption and inside the medium
https://www.physicsforums.com/threads/do-photons-move-slower-in-a-solid-medium.511177/
Like I said - it isn't correct to say you won't need to unlearn anything from Feynman - but you need to be quite advanced for it to be an issue.
Bottom line here - to start with stick with Feynman.
Thanks
Bill
As you can expect, both are right. But you want to keep things separate: your first half is about absorption, but then Feynman's thingy is about transmission/reflection: zero absorption (all photons either get transmitted or reflected). His dealing is that there is a probability for each of the two that depends on -- among other things -- the thickness of the glass. Has to do with interference between reflected and transmitted waves. (hence the prominence of the wavelength in the quantitative expressions). For the question: how a single photon can be subject to these interference expressions when it either reflects or transmits ? you are back in quantum mechanics (but simple wave mechanics and even simpler optics come up with good descriptions as well).
Just like with Feynmans ecellent expose about the double slit experiment: an individual photon, electron (, baseball ) interferes with itself !
Related to What actually happens when light meets a surface(QED or QM)?
1. What is the difference between QED and QM in regards to light interacting with a surface?
QED (Quantum Electrodynamics) and QM (Quantum Mechanics) are both theories that explain the behavior of particles and their interactions. QED specifically deals with the interaction of light (electromagnetic radiation) with matter, while QM covers a wider range of particles and their interactions.
2. How does light interact with a surface according to QED?
In QED, light is described as a stream of particles called photons. When these photons hit a surface, they can either be reflected, transmitted, or absorbed. The probability of each of these outcomes is determined by the properties of the surface and the energy of the photons.
3. What does QM tell us about the behavior of particles when light interacts with a surface?
QM explains that particles, including photons, have both wave-like and particle-like properties. This means that when light interacts with a surface, it can behave as both a wave and a particle. The exact behavior is determined by the properties of the surface and the energy of the photons.
4. Can light ever be stopped or completely absorbed by a surface?
According to QED and QM, it is not possible to completely stop or absorb light. This is because light has both wave-like and particle-like properties, and it can always find a way to continue propagating. However, certain surfaces and conditions can greatly reduce the amount of light that is reflected or transmitted, giving the appearance of being stopped or absorbed.
5. How do the laws of QED and QM explain the colors we see when light interacts with a surface?
The colors we see when light interacts with a surface are determined by the energy of the photons and the properties of the surface. QED and QM provide equations that describe the probability of different colors being reflected or transmitted based on these factors. The colors we perceive are a result of the specific combination of photons that are reflected or transmitted by the surface.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Biology and Medical
