quickAndLucky
- 34
- 3
Radio waves can go through walls and x Rays go through body tissue but the visible spectrum is blocked by both . Why is this the case?
mrnike992 said:
The reason why visible light can't travel through walls as easily as gamma rays or radio waves is because, to the visible light, there's something 'there' on a similar scale of length (wavelength) and time (frequency) that the gamma rays are too small and fast to interact with and the radio waves are too large and slow to interact with.
davenn said:radio waves are NOT slow, gamma rays are NOT fast
Dave
The science behind certain wavelengths passing through walls is related to the concept of electromagnetic radiation. Electromagnetic radiation is a form of energy that travels through space in the form of waves. The wavelength of electromagnetic radiation determines its properties, including whether it can pass through walls or not.
Some wavelengths are able to pass through walls because they have a shorter wavelength and higher frequency, allowing them to easily penetrate solid objects. On the other hand, longer wavelengths have a lower frequency and are not able to pass through walls as easily, making them more likely to be absorbed or reflected by the wall.
Materials that are dense and thick, such as concrete and metal, are effective at blocking certain wavelengths from passing through walls. These materials have a high density and can absorb or reflect the energy of the wavelength, preventing it from passing through.
Yes, certain wavelengths can be manipulated to pass through walls using specialized equipment such as amplifiers and filters. These devices are able to alter the properties of the wavelength, allowing it to pass through walls more easily.
No, it is not possible to completely block all wavelengths from passing through walls. Even the thickest and densest materials cannot block all wavelengths, as some will inevitably pass through due to their high energy and ability to penetrate solid objects.
