MHB What am I doing wrong? (Simplifying Rational Expressions)
The discussion focuses on simplifying the rational expression and identifying mistakes in the process. The original expression involves two fractions that need to be simplified through factoring. Key errors include illegal cancellation of terms and incorrect multiplication of polynomials. The correct approach emphasizes factoring first to identify restrictions on the variables before simplification. Proper application of the FOIL method is also highlighted as essential for accurate multiplication of binomials.
eleventhxhour
7a) Simplify and state any restrictions on the variables:
$$\frac{x^2-5xy+4y^2}{x^2+3xy-28y^2} ⋅ \frac{x^2+2xy+y^2}{x^2-y^2} $$
I'm not really sure what a good process would be to simplify this. This is what I tried to do, (below) which is wrong. Could anyone point out what I did wrong and what a better process to simplify it would be? Thanks!
My answer:
$$\frac{-5xy+4y^2}{3xy-28y^2} ⋅ \frac{2xy + y^2}{-y^2}$$
$$\frac{-10x^2y^2 + 4y^4}{-3xy^3+28y^4}$$
$$\frac{2y^2(-5x^2+2y^2}{y^3(-3x+28y)}$$
And then I'm not sure what to do.
Mathematics news on Phys.org
I would suggest factoring first, and then from this you can see the restrictions and then simplify:
$$\frac{(x-y)(x-4y)}{(x+7y)(x-4y)}\cdot\frac{(x+y)^2}{(x+y)(x-y)}$$
Hello, eleventhxhour!
What are you doing wrong? . . . Everything!
Simplify: .$$\frac{x^2-5xy+4y^2}{x^2+3xy-28y^2} ⋅ \frac{x^2+2xy+y^2}{x^2-y^2} $$
You have: .$$\frac{x^2-5xy+4y^2}{x^2+3xy-28y^2} ⋅ \frac{x^2+2xy+y^2}{x^2-y^2} $$
Then you canceled illegally:
. . $$\frac{{\color{red}\rlap{//}}x^2-5xy+4y^2}{{\color{red}\rlap{//}}x^2+3xy-28y^2} ⋅ \frac{{\color{red}\rlap{//}}x^2+2xy+y^2}{{\color{red}\rlap{//}}x^2-y^2} $$
And got: .[math]\frac{-5xy+4y^2}{+3xy-28y^2} ⋅ \frac{+2xy+y^2}{-y^2} [/math]Then you multiplied incorrectly.
You said: .[math](-5xy + 4y^2)(2xy + y^2) \:=\:-10x^2y + 4y^4[/math]
. . as if you never heard of "FOIL".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
