What am I doing wrong with this simple integral?
  • Thread starter Thread starter Physics_wiz
    Integral
Physics_wiz
I want to integrat x^-2 between -1 to 1. The answer shouldn't exist (should probably be something divided by 0) because the area is infinite between -1 to 1. But I integrate, and I get -x^-1 from -1 to 1. I then plug the bounds in and I get: [-(1)^-1] - [-(-1)^-1] which is -1 -1 or -2. What am I doing wrong?
Not true. You're right with your answer. One thing you will learn with integrals is that an infinite jump at any particular point in a function f(x) may correspond to a finite jump in its integral.
Why is the answer negative? I attached a picture of the graph, it still looks like it should be infinite to me.
Ok my apologies. You were correct in your arithmetic, but your answer is complete garbage. As far as I know you cannnot integrate over that interval. There are however cases where a function "blows up" but has a finite integral, so you must be careful (the only case I know of however is the dirac delta function, whose integral is 1 over infinite limits)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
