What amount of energy is needed to make a field of plasma?
In summary, it would require a lot of energy to create a sphere-shaped plasma field using an EM field. It is possible to create a suitably charged plasma bubble around an object, but I'm not sure if it is possible to create arbitrary shapes of plasma. It would likely take more energy than is available to divert or repel a projectile.
Jonathan Brandre
How much energy would be required to generate a spherical field of plasma using an EM field? I have heard that EM fields can excite atoms in the air to create plasma- however, this may be incorrect. If correct, how much energy would be needed and would it fry anything inside because of the massive amount of heat being generated or would that heat radiate outward, creating a sort of force-field?
Depends on the size of the plasma, the density of the gas and how efficiently the gas absorbs the input radiation.
There are plasma windows.
When I was at michigan, our lab had a plasma source only drew a current of about 20 milliamps. I believe it was a Xenon plasma. The amount of energy needed highly depends on the density, temperature of the plasma and the ionization percentage. For a low temperature plasma, it wouldn't take much energy, just the right conditions (vacuum, thermoelectric filament or radio frequency heating, confinement)
It may not fry anything if you were to put it inside the plasma. If it was a low temperature plasma, inserting a foreign object into it would likely just put it out. They are working on medical plasmas that are safe to touch.
At high temperature, there wouldn't be a "force field". Plasma is all about confinement. Introducing a foreign object even into a fusion reactor would definitely obliterate said object, but it would also destroy confinement and shut the plasma down,
At worst the foreign object would be scorched unless it was very, very small. The plasma density is simply too low to obliterate the object otherwise.
I'm not sure. What if an edge localized mode was present? In the core region, you may be correct, but the most turbulent region is at the edge and/or divertor region. The divertor has to be designed to withstand 10MW/m^2 of power. Surely that would vaporize anything it touched.
We're talking about perhaps a few grams of plasma at most within the entire reaction chamber, and only a small part of that is going to touch the object. Even though the plasma temperature is many millions of degrees, there simply isn't enough total heat stored in the plasma to vaporize an entire object.
Existing test reactors store up to a few MJ of energy in its plasma, ITER will store hundreds of MJ (https://www.researchgate.net/figure/234922099_fig2_The-plasma-stored-energy-top-panel-the-central-temperatures-middle-panel-and-the ) and a power-plant-sized reactor will probably store a few GJ.
Perhaps I was mistaken then. Is that enough to vaporize an object? (I'm assuming something like a hand tool or similarly sized object)
The wall components are made out of tungsten, which has the highest melting point of any element. An edge localized mode can melt pieces of the wall. I think it highly depends on the location in the plasma, but at the right spot I'm sure an iron object would be pretty much obliterated
400 MJ is sufficient to evaporate ~60 kg of copper. Energy needed to heat and melt it is taken into account.
I guess in the case of a containment failure the reactor isn't destroyed because the heat gets deposited all across the interior instead of concentrated in one spot. My mistake.
The OP intends this to be some sort of force-field. In which case I've got two questions based on this post and the discussions around it:
1) Is creating a suitably charged plasma bubble around an object possible? Is there any way to create arbitrary shapes of plasma (like a sphere of defined thickness) and sustain it?
2) Regarding the energy in the plasma is it enough to divert/repel a projectile? I'm wondering if a plasma-shield (even if it were possible) would have enough time to melt, evaporate and harmlessly disperse something like a high-velocity rail gun slug.
Maybe. You could set up a very large potential between a sphere and a shell surrounding said sphere to the breakdown voltage in the material between. Probably wouldn't sustain itself.
Probably not. Ever run your finger through a candle flame quickly? That is a relatively high mass-density plasma and your finger goes right through it. Fusion plasmas have mass density less than that of air. The only way a plasma could interact with a physical projectile would be through heat transfer, but a projectile would be moving far too fast to gain any significant energy that way.
You'd be better off setting up some kind of magnetic deflection device.
I was thinking along the lines of an external plasma. I.e. can you build a device that when activated creates a bubble around it, not within a chamber of any description.
That's my intuitive thought, that even if it were possible to put a bubble of plasma around an object it would be trivial to design a weapon that could shoot through it.
Even if say you had a free chunk of plasma in space, it would either
1)Disperse rapidly onto space (remember it consists of high velocity particles)
2) radiate all its energy away through bremmstrahlung and cool down to a normal gas
See the plasma windows I mentioned in post 2. They are sufficient to hold the pressure difference between vacuum and the atmosphere, but they won't stop a bullet. Oh, and all existing plasma windows are millimeter- to centimeter-sized and need a lot of power.
Related to What amount of energy is needed to make a field of plasma?
1. How is energy used to create a field of plasma?
The energy needed to create a field of plasma is typically supplied through an external power source, such as an electrical current or electromagnetic waves. This energy is then converted into heat, which causes the gas to ionize and form plasma.
2. What factors affect the amount of energy needed to make a field of plasma?
The amount of energy required to make a field of plasma depends on several factors, including the type of gas used, the temperature and pressure of the gas, and the strength of the external power source. These factors can vary depending on the specific application and desired properties of the plasma.
3. Can the amount of energy needed to create a field of plasma be accurately calculated?
While there are mathematical models that can estimate the amount of energy needed to create a field of plasma, the exact amount may vary in practice due to experimental conditions and limitations. Therefore, it may be more accurate to measure the energy used during the process rather than rely on calculations.
4. Is there a minimum amount of energy required to create a field of plasma?
Yes, there is a minimum amount of energy needed to create a field of plasma. This is known as the ionization energy, which is the minimum amount of energy required to remove an electron from an atom or molecule and create a positive ion. This value varies depending on the gas being used.
5. Can energy be recycled or reused in plasma fields?
In some cases, yes. In fusion reactors, for example, the heat energy released from the plasma can be used to generate electricity, which can then be used to power the external power source and sustain the plasma field. However, in other applications, such as plasma processing, the energy is often dissipated and cannot be recycled.
  • Astronomy and Astrophysics
  • STEM Academic Advising
  • Nuclear Engineering
