What are angular momentum and torque?
In summary, torque and angular momentum are both important quantities in rotational motion. Torque is a measure of the rotational force applied to an object, while angular momentum is a measure of the amount of rotational motion an object possesses. They are related but not equivalent, as torque can change the angular momentum of an object. The dimension of torque, N*m, may seem like energy, but it is a distinct physical quantity. Angular momentum is not simply mass times angular velocity because it also takes into account the distribution of mass around the axis of rotation. Inertia, or the resistance to change in rotational motion, depends on both the amount and distribution of mass, leading to the concept of moment of inertia. It is important to understand the mathematical definitions of
erocored
30
Wikipedia says that they are the equivalents of momentum and force in rotational motion but I don't understand why this comparison is possible. The torque's dimension is N*m it seems like energy. What is this energy? Why angular momentum is not mass times angular velocity?
Same dimension doesn't imply the same physical quantity. For energy (work) the Force [N] is parallel to the distance [m]. For torque they are orthogonal.
Because rotational inertia depends on the distance of the mass to the rotation axis, not just on the amount of mass.
Likes Lnewqban, vanhees71 and etotheipi
Well it's sort of by definition, but the motivation is like @A.T. pointed out, that you expect the angular momentum of the same amount of mass spinning at the same angular velocity at a large radius to be greater than at a small radius. For a single particle, define ##\vec{L} = \vec{r} \times \vec{p} = m\vec{r} \times \dot{\vec{r}}##. Then the angular momentum of a rigid body hinged at the origin is just$$\vec{L} = \sum_i m_i \vec{r}_i \times \dot{\vec{r}}_i = \sum_i m_i \vec{r}_i \times (\vec{\omega} \times \vec{r}_i) = \sum_i m_i (r_i^2 \vec{\omega} - (\vec{\omega} \cdot \vec{r}_i) \vec{r}_i)$$with components$$L_a = \sum_i m_i (r_i^2 \omega_a - \omega_b (\vec{r}_i)_b (\vec{r}_i)_a )$$It's now convenient to define the "moment of inertia", with components as follows$$I_{ab} = \sum_i m_i (r_i^2 \delta_{ab} - (\vec{r}_i)_a (\vec{r}_i)_b)$$so that$$I_{ab} \omega_b = \sum_i m_i \left( r_i^2\omega_a - (\vec{r}_i)_a (\vec{r}_i)_b \omega_b \right)$$which is just the same as our ##L_a##, i.e. $$L_a = I_{ab} \omega_b, \quad \text{or} \quad \vec{L} = I\vec{\omega}$$this ##I## is the moment of inertia tensor, which takes the angular velocity vector to the angular momentum vector. Note that ##\vec{L}## is not necessarily even parallel to ##\vec{\omega}##.
Likes erocored and vanhees71
Momentum is a conserved quantity and force is its rate of transfer. Similarly angular momentum is a conserved quantity and torque is its rate of transfer.
Because that quantity is not conserved. Nobody cares about it.
Likes Frigus, erocored, PeroK and 2 others
erocored said:
... Why angular momentum is not mass times angular velocity?
Two rotating objects can have identical mass and still show different resistances to change the magnitudes of their angular velocities.
The object with more mass concentrated near the axis of rotation will have less inertia, and will increase or decrease its angular velocity more quickly under the action of an applied torque, than the object with more mass concentrated far from the axis of rotation.
The concept of moment of inertia considers that characteristic, while the concept of mass does not.
Please, see:
https://en.m.wikipedia.org/wiki/Moment_of_inertia
:cool:
Likes erocored, PeroK, vanhees71 and 1 other person
It may be useful to consider the the dictionary definition of the word "moment" in this context. $$moment=importance$$ Torque is the ##moment## of force. Angular momentum is the ##moment## of momentum. Moment of Inertia is the ##moment## of the mass.
In each case the ##moment## is calculated using the nearest distance to the chosen axis, because for rotation that is what is important.
  • Skeptical
Likes Motore
A quick trip to google suggests that the mathematical definition of "moment" is of more importance than the English dictionary definition.
https://en.wikipedia.org/wiki/Moment_(mathematics)
Likes vanhees71 and hutchphd
Perhaps. I found it useful to know the archaic English when teaching it. Otherwise it lacks color.
Likes vanhees71
Crack a book! Torque is defined in such a way that makes it proportional to angular acceleration for a rigid body. Angular momentum is defined in such a way that makes it conserved in the absence of a net external torque. Any decent college-level introductory physics textbook will cover this in full detail.
Likes erocored and etotheipi
Well, it's not that simple except if you consider the rotation around a body-fixed axis. A typical example is a physical pendulum. In the general case, you need the tensor of inertia. It's the most chalenging subject of the intro mechanics lecture.
Likes etotheipi
Related to What are angular momentum and torque?
1. What is angular momentum?
Angular momentum is a measure of an object's rotational motion. It is defined as the product of an object's moment of inertia and its angular velocity. In simpler terms, it is the amount of rotational energy an object possesses.
2. How is angular momentum different from linear momentum?
Angular momentum is a measure of rotational motion, while linear momentum is a measure of straight-line motion. Angular momentum takes into account an object's mass, speed, and distance from the axis of rotation, while linear momentum only considers an object's mass and velocity.
3. What is torque?
Torque is a measure of the force that causes an object to rotate around an axis. It is calculated by multiplying the force applied to an object by the distance from the axis of rotation to the point where the force is applied.
4. How are angular momentum and torque related?
Angular momentum and torque are closely related, as torque is the force that causes changes in an object's angular momentum. The greater the torque applied to an object, the greater the change in its angular momentum.
5. What are some real-life examples of angular momentum and torque?
Some examples of angular momentum and torque in everyday life include the spin of a top, the rotation of a bicycle wheel, and the movement of a gymnast on a balance beam. In the world of physics, these concepts are also important in understanding the behavior of planets in their orbits and the motion of spinning objects in space.
  • Mechanics
  • Mechanics
