What are cosine and sine functions called in relation to Pi?
In summary: I apologize. I should have been more clear. I thought it was obvious that I was talking about evaluating sine and cosine with ℝ values. So, I want to clear up the things I said, because I think they might be wrong. I should say, I am not a mathematician. I don't know what the truth is. I am just trying to explain what I was thinking. So, I think that what a mathematician would say is that the period of a sine wave is 2π radians. And that's the only mathematically correct answer to the question "what is the period of a sine wave". And this is true, because if you
Matt Benesi
134
1)* What are sine and cosine functions called in relation to Pi?
2) What is the exponential function called in relation to cosine and sine functions?
3) What are the other smooth, continual nested (or iterative) root functions (that are similar to sine and cosine) called in relation to their constants? (see: https://www.physicsforums.com/threa...coefficients-of-an-alternating-series.964892/ ) 1* Are they called decomposition functions, since they decompose angles into ratios?
Mathematics news on Phys.org
I have no idea what your questions mean. Could you elaborate?
Is there a name for the relationship between Pi and the sine/cosine functions?
Like "Pi is the <xxxxx> of cosine and sine" and "Pi is <xxxx> to sine and cosine". Not just "the period". Is there another name for it?
Extend this to question 2
: "Cosine and sine are the <xxxx> of the exponential function" and "sine and cosine are <xxxx> to the exponential function.
This doesn't explain anything: a repetition is no explanation.
##\pi## is a zero of the sine function. Otherwise, sine and cosine are just periodic functions. They are related to a circle, which is why ##\pi## plays a role, but it is the circle which is crucial, not ##\pi##.
The real exponential function has nothing to do with the sine and cosine functions. Will say, the complex connection has to be derived, it is not a natural one. Therefore there isn't name for it.
Generally, only things are named, if they are attributed to a person who found them, or if they are frequently used. We use the sine function a lot, but to have ##\pi## as a zero, you already have to make restrictions, e.g. ##\sin(x+1)## hasn't ##\pi## as a zero. Your question doesn't make a lot of sense, which is why you were asked for an explanation, driven by the hope we could answer what really bothers you. If it's only what you wrote, then look for something useful you can name.
It is still pointless. E.g. the periods of sine and cosine can be arbitrary, same as the zeros. Why bound them to ##\pi##? That makes no sense. They are already related via the unit circle and everybody knows this relation. There is no gain in naming the obvious.
The same is true for the formula for ##e^{i \varphi}##, which is called Euler's formula. Why should someone want to rename the exponential function? The name fits far better to its real meaning: exponential growth in nature. Euler's formula is in the end a consequence of integration, namely why the points on the unit circle can be described by it.
To pick a certain formel out of myriads is a deliberate act and does not require names. Names are given if there is a sense behind. I cannot see any sense in the above. It appears to me actually as an advanced version of pointless numerology.
Likes Klystron
@Klystron- there is nothing mystical about numbers, nor the language used to describe them. At least as far as I can tell.
I mentioned the natural log of #2/pi joke, because that's what it is. A joke. Modern English came about after Napier mentioned logarithms, after old Norse "log" became a euphemism for something else. It's not numerology. It's linguistics.
Numerology would be like saying 2^4*3*the 12th prime = the 12th prime *3*4^2, which is why the founding fathers of the USA picked that date. It would be like saying 2*3^2 * the (2*3*2) prime = a number which has digits that in base 10 are the exact numbers of the most common isotope of carbon, which is part of all life. It would be like saying this twelfth prime is the percentage of water's boiling point that human body temperature is. It would be like creating an alphabet, in antiquity, that has an alphanumeric substitution with 2*the 12th prime as Gd, and 2*12 as 24, or the opposite of the answer to life, the universe, and everything, which is 42 (or DB, not bd!).
Or you need Douglas Adams to point out that... well, 4^2*3 * the (3*4*2)th prime =4272. We all know that 24*3=72, which almost was the founding date of the USA (look it up, it was almost 7-2-1776 instead of 7-4). So we better subtract 42*the 12th prime from it to get back to 2718. I am so oblivious sometimes. Sigh.
But that's numerology. And it's sort of interesting, if "pointless" as fresh_42 says. What I was talking about was more... a natural log of number 2 joke. Which.. I think is funny. But I will avoid thinking of math as funny. Because it's not supposed to be funny. It's serious.
Back to a fresh_answer:
Ok, I thought it was obvious that I was talking about evaluating sine and cosine with ℝ values, but I think I need to include more information from question 3 since I'm not interested specifically in the periodic nature of the functions. I was hoping there was some common mathematical name that I wasn't aware of, describing pi and it's relationship to cosine and sine, which would also apply to another thing I am researching.
I am looking for the name of the group of constants and functions that allow one to create continual nested roots, so I can find the generating formula for the terms of the functions (since I already know how to generate the constants for the functions, and extract terms).
So Pi is to [itex]\sqrt{2+sqrt{2+...}}[/itex] like 2.5351045638... is to [itex]\sqrt{.75+\sqrt{.75...}}[/itex]. Pi allows one to smoothly iterate between [itex]\sqrt{2}[/itex] to [itex]\sqrt{2+sqrt{2}}[/itex] to [itex]\sqrt{2+sqrt{2+\sqrt{2}}}[/itex], while ~2.54 allows you to do the same with .75 (given terms of the expansion).
And pi is the only one on the n=2 line that contains every prime, in order, in the functions that extract its #2 roots smoothly. #2. lol.
Related to What are cosine and sine functions called in relation to Pi?
1. What is the definition of cosine and sine functions in relation to Pi?
Cosine and sine functions are mathematical functions that describe the relationship between the sides and angles of a right triangle. In relation to Pi, cosine and sine functions represent the ratio of the adjacent and opposite sides of a right triangle to its hypotenuse, where Pi is used as the unit of measurement.
2. Why are cosine and sine functions important in mathematics?
Cosine and sine functions are important in mathematics because they are used to model and solve a wide range of real-world problems, from calculating the trajectory of a projectile to analyzing the behavior of electrical circuits. They are also fundamental to many other mathematical concepts, such as Fourier series and complex numbers.
3. How do cosine and sine functions relate to the unit circle?
In the unit circle, cosine and sine functions represent the x and y coordinates of a point on the circle, respectively. The angle formed by the radius of the circle and the x-axis is equivalent to the input value of the cosine function, while the angle formed by the radius and the y-axis is equivalent to the input value of the sine function.
4. Can cosine and sine functions be negative?
Yes, cosine and sine functions can be negative. The values of these functions can range from -1 to 1, depending on the angle input. This is because the sides of a right triangle can have negative values, which will affect the ratio of the sides to the hypotenuse.
5. How are cosine and sine functions used in trigonometry?
Cosine and sine functions are essential in trigonometry as they are used to calculate the lengths of sides and angles in a right triangle. They are also used in trigonometric identities and equations, which are used to solve various problems in geometry, physics, and engineering.
  • Other Physics Topics
