MHB What are f(0), f(1), and f(-1) in the equation f(x)= 2x^2- 3x+ 7?
  • Thread starter Thread starter mathdad
In the equation f(x) = 2x^2 - 3x + 7, the value of c is determined to be 7 from f(0). The values of a and b are found by solving the equations derived from f(1) = 6 and f(-1) = 12, resulting in a = 2 and b = -3. The function can be confirmed by substituting these values back into the original equation. The calculated values for f(0), f(1), and f(-1) are consistent with the derived coefficients. The discussion emphasizes the satisfaction of solving the math problem.
mathdad
Given f(x) = ax^2+bx+c, where a, b and c are constants, if f(0)=7,what is the value of c? Given that f(1)=6 and f(-1)=12, find the value of a and b.
My Work:
f(0) = 7
7 = a(0)^2 + b(0) + c
7 = 0 + 0 + c
7 = c
f(1) = 6
6 = a(1)^2 + b(1) + 7
6 = a + b + 7
6 - 7 = a + b
- 1 = a + b...Equation A
f(-1) = 12
12 = a(-1)^2 + b(-1) + 7
12 = a - b + 7
12 - 7 = a - b...Equation B
Equations A and B produce a system of equations.
Solving the system of equations for a and b, I found a to be 2 and b to be -3.
Is this correct?
Mathematics news on Phys.org
It's easy to check it yourself, isn't it? You are saying that a= 2, b= -3 and c= 7 so you are saying that f(x)= 2x^2- 3x+ 7. So, using that formula, what are f(0), f(1), and f(-1)?
Ok.
- - - Updated - - -
Ok. It feels good to solve a math problem.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
