Josh111
- 37
what are generator neutral earthing resistances. Are they necessary for small generators?
(50 KW 3 phase 120/208v.)
Josh111 said:what are generator neutral earthing resistances. Are they necessary for small generators?
stewartcs said:Devices that limit fault current. Shouldn't be required on a small generator but depends on the application.
CS
A generator neutral earthing resistance is a component used in electrical power systems to limit the flow of current in the event of a ground fault. It is connected between the neutral point of the generator and the ground to provide a path for fault currents and prevent damage to equipment and potential hazards to personnel.
A generator neutral earthing resistance is necessary because it helps to protect the generator and other equipment from damage in the event of a ground fault. It also helps to prevent electrical shock hazards to personnel by limiting the flow of fault currents.
The value of a generator neutral earthing resistance is determined through various factors, such as the size and rating of the generator, the type of electrical system, and the level of fault current that the resistance needs to handle. Typically, the resistance is chosen to limit the fault current to a safe level, usually between 5-10% of the generator’s rated current.
The three main types of generator neutral earthing resistances are neutral grounding resistors, neutral grounding transformers, and solidly grounded systems. Neutral grounding resistors are the most commonly used and are connected in series with the neutral point of the generator. Neutral grounding transformers use a transformer to ground the neutral point. Solidly grounded systems have no neutral earthing resistance and instead rely on the low resistance of the neutral point of the generator.
Generator neutral earthing resistances should be tested regularly to ensure proper functioning and to identify any potential issues. The frequency of testing depends on factors such as the size and type of the generator, the type of resistance used, and the recommendations of the manufacturer. In general, it is recommended to test the resistance at least once a year, or whenever there is a significant change in the system.
