Undergrad What are P03 procedures or guidelines?
  • Thread starter Thread starter Old Person
    Cosmology
P03 refers to a specific numerical procedure or guideline used in simulations related to dark matter halo profiles in galaxies, as discussed in the paper "The Inner Structure of ΛCDM Halos III: Universality and Asymptotic Slopes" by Navarro et al. The author initially sought clarification on P03, noting it was not listed in the references. After some discussion, it was identified that P03 is actually a code ID, specifically "10.T." This highlights the importance of understanding numerical setups in astrophysical simulations. The conversation emphasizes the need for precise references in academic papers.
Old Person
TL;DR
A paper refers to P03 as if it is a well known set of procedures or guidelines. It gives no reference to any literature for P03. What is it?
Hi.
I'm not sure if this should be in Cosmology or Astronomy - a moderator can feel free to move it if required. Also the prefix (study level) may be an I or an A, you can change that, just thought I'd get a bigger audience with an I. I'm trying to read this paper:
"The Inner Structure ofΛCDM Halos III: Universality andAsymptotic Slopes", by Navarro et.al. , 2018
Available on Arxiv here:
https://arxiv.org/abs/astro-ph/0311231
Background: It's about determining a profile (a distribution) for the Dark Matter halo in galaxies.
In section 2 they write:
The numerical set up of our simulations follows closely the procedure described by P03, where the interested reader may find a thorough discussion of our initial conditions generating scheme, the choice of N-body codes and integrators,as well as the criteria adopted to optimize the choice of the numerical parameters of the simulations. For completeness, we include here a brief discussion of the main numerical issues, but refer the reader to P03 for a more detailed discussion.
They refer to PO3 in a few other places. I've looked through the references at the end, PO3 doesn't seem to be mentioned. Does anyone know what PO3 is? Can I get a reference to some literature about PO3?
Minor note: P03 seems to have a zero not a letter O: (letter P) - (number zero) - (number three).
One guess is that P03 was some marker they were going to update with a reference in a final version of the paper but it hasn't happened in the Arxiv version. However, maybe someone working in the area might know what P03 is.
Thank you for your time and attention.
Space news on Phys.org
Look in the paragraph just after equation (2) in section 1 (it's in the left column of page 2, just opposite the paragraph you mention that references P03).
Found it, thanks. I'm an idiot.
Technically, that is a code ID.10.T.
You're welcome.
  • · Replies 105 ·
15K
  • · Replies 62 ·
10K
