awholenumber
- 200
- 10
If the slope of the curve (derivative) at a given point is a number .
This question has no relation to the title. Partial differentia equations are not the same thing as derivatives (even though they are related).rosekidcute said:If the slope of the curve (derivative) at a given point is a number .
Is it possible to understand partial differential equations in terms of a working example of something ?From a pdf :
Basic Terminology
An ordinary differential equation (ODE or just DE) is a system with the following ingredients:An independent variable (usually t think ”time”or x think ”position”) that derivatives are taken with
respect to.
A dependent variable, i.e. function of the independent variable, e.g. y = y(t) ”the variable y which
is a function of t”.
A multi-variable function F that describes a relationship between the derivatives of the dependent
variable (taken with respect to the independent variable)
F(t, y, dy/dt, d2y/dt2 , . . . ,dny/dtn ) = 0.
Wrong website. This is about differential equations. Before going through that you should become familiar with differentials. An introductory calulus textbook or website if the Wiki link I gave you is too abstract.rosekidcute said:Thanks for the reply ,
I was going through this website here ,
https://17calculus.com/differential-equations/
Sure. Once you're comfortable wit Algebra, Calculus I and II, there are plenty in Calculus III on partial derivativesIs it possible to understand partial differential equations in terms of a working example of something ?
I suspect you have some specific topic that interests you ?rosekidcute said:This is the only thing i could think of .
All you're doing here is giving definitions of a few terms, a very long way from being able to solve ordinary differential equations (involving single-variable functions) or partial differential equations (involving multi-variable functions).rosekidcute said:It is ok , i sort of understand it with my new avatar .
Some points i tried to narrow down .
Differential calculus - which is looking at the instantaneous rates of change of objects with respect to some variables. We have the notion of the derivative of a function
The slope of the curve (derivative) at a given point is a number
Partial derivative - A derivative of a function of two or more variables with respect to one variable, the other(s) being treated as constant.
An equation that involves the derivatives of a function of several variables is a "partial differential equation"
BTW, what does having a new avatar have to do with understanding anything?
Differential equations are equations that involve the derivatives of various orders of some unknown function f. These derivatives represent the rates of change of some quantity with respect to some other quantity. You don't start off knowing the function, so it makes no sense to talk about finding its derivative.rosekidcute said:First you have a function f(x)
Then you can take the derivative of that function from first principles
Then you get f'(x) or dy/dx
That dy/dx , the slope of the curve (derivative) at a given point is a number .
I have been unnecessarily thinking about the cause behind why differential equations have dy/dx or f'(x) in them .I guess there is no need to think about it that way .
Mark44 said:Differential equations are equations that involve the derivatives of various orders of some unknown function f. These derivatives represent the rates of change of some quantity with respect to some other quantity. You don't start off knowing the function, so it makes no sense to talk about finding its derivative.
A derivative simply specifies the rate at
which a quantity changes. In math terms, the derivative of a function f(x),
which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates
how f(x) is changing at any value of x. The function f(x) has to be continuous
at a particular point for the derivative to exist at that point.
which a point mass quantity changes. In math terms, the derivative of a function f(x),
Correct, and only in this case, with many variables, does it make sense to talk about partial derivatives.rosekidcute said:Ok , The independent variable is x. The dependent variable is f(x)
In this ,
The function 1 , 4 , 5 are functions of several variables right ?
A derivative simply specifies the rate at which a point mass quantity changes. In math terms, the derivative of a function f(x), which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates how f(x) is changing at any value of x. The function f(x) has to be continuous at a particular point for the derivative to exist at that point.
In a sense, these are equations where the " input data" is given in terms of partial derivatives: you are given a numerical relation involving an unknown function and some of its partial derivatives and your goal is to identify the function(s) satisfying said relations .
the "wave equation" andPartial derivatives are a kind of extension to functions of several variables such as f(x,y) . if you keep y constant, e.g. at Y1 then the partial derivative wrt x of f is the derivative of the now single variable function f(x,Y1)
This quote is missing context. In general , derivatives aren't about how point mass quantites change.A derivative simply specifies the rate at which a point mass quantity changes. In math terms, the derivative of a function f(x), which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates how f(x) is changing at any value of x. The function f(x) has to be continuous at a particular point for the derivative to exist at that point.
Do a web search for "wave equation" and "heat equation".rosiekidcute said:the "wave equation" and
the "heat equation "
are such types of equations right ?
If you're interested in differential equations, get a textbook or look at an online course. Any textbook on differential equations will have a definition of the term, as will online sites such as Wikipedia.rosekidcute said:What is a differential equation ?
It is an equation involving an unknown function (solution) and its derivatives
This much is OK , right ?
Partial differential equations (PDEs) are mathematical equations that involve multiple independent variables and their partial derivatives. They are used to describe physical phenomena that vary in space and time, such as heat transfer, fluid flow, and electromagnetic fields.
PDEs are important because they are used to model and analyze many real-world problems in fields such as physics, engineering, and economics. They provide a powerful tool for predicting the behavior of complex systems and designing solutions to practical problems.
The main difference between PDEs and ordinary differential equations (ODEs) is the number of independent variables. ODEs involve only one independent variable, while PDEs involve multiple independent variables. This makes PDEs more complex and challenging to solve, but also allows for a more accurate representation of real-world phenomena.
There are several techniques for solving PDEs, including separation of variables, method of characteristics, and numerical methods. Each technique has its own advantages and is suited for different types of PDEs. Choosing the appropriate technique depends on the specific problem being solved.
PDEs have numerous applications in various fields. For example, in physics, they are used to model heat transfer, fluid dynamics, and wave propagation. In engineering, they are used to design structures and optimize processes. In economics, they are used to model financial markets and analyze business strategies.
