What are some common calculations in Brownian motion?
In summary, the first question is about the moments of a normal distribution. The second question is about the incremets on a brownian motion being independant. The third question is about the mgf of a normal distribution. The fourth question is about the difference between B_j and B_k and the fifth question is about the equation for the mgf. The sixth question is about the equation for the expectation. The seventh question is about the equation for the variance. The eighth question is about the equation for the standard deviation. The ninth question is about the equation for the maximum. The tenth question is about the equation for the minimum.
Jason4
28
I need to answer these questions, but I don't have a clue what they mean. Could anybody shed some light?
Find:
(a) $E({B_1^4})$
(b) $E({B_1^6})$
(c) $E(e^{B_1})$
(e) $E({5B_1}^4+{6B_1}^2+{5B_1}^3)$
(e) $E(B_2 B_3)$
(f.) $E(e^{B_2+B_3})$
Hello,
Yes, B indeed stands for a brownian motion, so you have to keep the basic properties in mind.
B0 = 0
Bt-B0 follows a normal distribution with mean 0 and variance (not standard deviation) t.
So in order to solve most of these questions, you need to know the moments of a normal distribution.
For the one involving B2*B3, you have to know that the incremets onf a brownian motion are independent. So in particular, B2*B3=(B3-B2)*B2+B2^2. So computing the expectation knowing the independence is easy.
For question f, you have to know the mgf of a normal distribution, that's all (subtract B0=0 if you have trouble seeing it).
Note for later : the advanced probability is the first thing I look for when I come at MHB, there's no need to send me a PM. If I can answer, I'll answer, if not, I'll try or I leave it :p
I'm absolutely perplexed. Could you work through one of the problems so I get an idea of how to do the other problems? (I promise this isn't a homework assignment; it's an exercise sheet that is... meant to help familiarize me with the "basics.") I'm looking through a zillion stochastic calculus texts, but still don't have a clue.
I'm not scarce on details because it could be an assignment, but trust me you just need the basic properties of a brownian motion to solve these questions. They can be found here : http://en.wikipedia.org/wiki/Brownian_motion#Mathematics (it can be B or W, most of the time, people don't make any difference)
For example the first one, just note that B_0=0, so B_1 = B_1 - B_0, but the third property says that B_1-B_0 follows a normal distribution N(0,1-0), so you have to get the 4th moment of a standard normal distribution. (I think it's 3, you can get it by computing the integral or just looking on the internet).
It's always this trick, you make appear the difference between B_j and B_k and you work on it with the properties you're given. Just give it a try :p I really learned about brownian motion 5 months ago...
Okay, I think I see.
$B_1\sim\textbf{N}(0,1)$
So: $E({B_1})=E(X)=0$, $E({B_1}^2)=E(X^2)=1$, etc.(a) $E({B_1^4})=E(X^4)=3$
(b) $E({B_1^6})=E(X^6)=15$
(e) $E({5B_1}^4+{6B_1}^2+{5B_1}^3)=5E(X^4)+6E(X^2)+5E(X^3)=5(3)+6(1)+5(0)=21$
Yep, that's a good start ! :)
(e) $ E(B_2 B_3)=E({B_2}^2))=(0)^2+2=2$
(c) $ E(e^{B_1})=e^{1/2}$
(f.) $E(e^{B_1+B_2})=e^{B_1}e^{B_2}=e^1e^{3/2}=e^{5/2}$
That's almost perfect. For the latter one, it's $E[e^{B_1+B_2}]=E[e^{B_1}]E[e^{B_2}]=e^{1/2}e^{2/2}=e^{3/2}$
Maybe you ought to put more details for the step, especially for (e).
See, not that difficult ? :p
Oops, f) should have been: $E[e^{B_2+B_3}]$
Now only ten more questions! Suppose I should start a new thread.
FAQ: What are some common calculations in Brownian motion?
What is Brownian Motion?
Brownian Motion is the random movement of particles suspended in a fluid due to collisions with the surrounding molecules.
Who discovered Brownian Motion?
Brownian Motion was discovered by Robert Brown, a Scottish botanist, in 1827 while studying pollen grains under a microscope.
What is the significance of Brownian Motion?
Brownian Motion is significant because it provided evidence for the existence of atoms and molecules, which was a major breakthrough in the field of physics.
What is the relationship between Brownian Motion and temperature?
The speed and intensity of Brownian Motion is directly proportional to the temperature of the fluid. As temperature increases, so does the kinetic energy of the particles, causing them to move more rapidly and exhibit more random motion.
How is Brownian Motion used in scientific research?
Brownian Motion is used in various fields of research, such as physics, chemistry, and biology, to study the behavior of particles and molecules in a fluid. It is also used in the development of models and theories, such as the kinetic theory of gases and the diffusion equation.
