What Are the Boundary Conditions for l=0 with Negative Energy?
In summary, for the given problem, we can use the general solution for a bound state with ##l=0##, and apply the boundary conditions at the boundaries ##r=a_1## and ##r=a_2## to solve for the coefficients. This will give us the correct wavefunction for the bound state with ##l=0## and energy ##E<V_0##.
Dario SLC
The question is basically find the boundary conditions when ##l=0##, for energies minor than 0.
$$V(r)=\begin{cases}
& 0\text{ $r<a_0$}\\
&V_0\text{ $a_0<r<a_1$}\\
& 0\text{ $r>a_1$}\\
\end{cases}
-\frac{\hbar^2}{2m}u''+\left(V(r)+\frac{l(l+1)\hbar^2}{2mr^2}\right)u=Eu
when ##u(r)=R(r)r##.
Like it is bound states because ##l=0## and the energy ##E## is minor than ##V_0##, the radial Schrödinger equation is:
-\frac{\hbar^2}{2m}u''+V(r)u=Eu
then it will be necessary to resolve:
$$\begin{cases}
-\frac{\hbar^2}{2m}u''=Eu\text{ $r<a_1$ and $r>a_2$}\\
-\frac{\hbar^2}{2m}u''+V(r)u=Eu\text{ $a_1<r<a_2$}
\end{cases}
Is correct solve this equation like an unidimensional motion?, ie the boundary conditions there are for the three region:
\begin{cases}
u_1(a_1)=u_V(a_1)\\
u'_1(a_1)=u'_V(a_1)\\
u_2(a_2)=u_V(a_2)\\
u'_2(a_2)=u'_V(a_2)\\
\end{cases}
when ##u_1=Ae^{kr}## and ##u_2=De^{-kr}##, with ##k=\frac{\sqrt{2mE}}{\hbar}##, here apply two boundary conditions:
becomes from ##-\infty## the part with exponential negative diverge, contrary, ##+\infty## the part with exponential positive diverge, therefore the constant called B and C respectly there are zero (##u_1=Ae^{kr}+Be^{-kr}\text{, and } u_2=Ce^{kr}+De^{-kr}##).
and ##u_V=A_Ve^{k'r}+B_Ve^{-k'r}## with ##k'=\frac{\sqrt{2m(V_0-E)}}{\hbar}##.
I don't really sure that it is was correct, mainly because ##r\geq0## and the process used for the unidimensional motion would be not valid here.
In this cases, the solution for ##u_1## and ##u_2## should be with the exponentials negatives?
Thanks a lot!
Your approach seems mostly correct. However, since we are dealing with a bound state, we should use the exponential functions with negative exponents for both regions, i.e. ##u_1=Ae^{-kr}+Be^{kr}## and ##u_2=Ce^{-kr}+De^{kr}##. This is because the wavefunction must decay to zero at infinity. Also, the boundary conditions at infinity should be ##u_1(\infty)=u_2(\infty)=0##, since the potential is zero outside the region ##r<a_1## and ##r>a_2##. This means that both B and C should be zero. The boundary conditions at ##r=a_1## and ##r=a_2## should be ##u_1(a_1)=u_2(a_2)=u_V(a_1)=u_V(a_2)## and ##u'_1(a_1)=u'_2(a_2)=u'_V(a_1)=u'_V(a_2)##. This ensures that the wavefunction and its derivative are continuous at those points.
Another way to approach this problem is to use the general solution for a bound state with ##l=0##, which is given by ##u(r)=A\sin(kr)+B\cos(kr)## for ##r<a_1## and ##r>a_2##, and ##u(r)=C\sin(k'r)+D\cos(k'r)## for ##a_1<r<a_2##, where ##k=\frac{\sqrt{2m(E-V_0)}}{\hbar}## and ##k'=\frac{\sqrt{2mE}}{\hbar}##. Then, using the boundary conditions at ##r=a_1## and ##r=a_2##, we can solve for the coefficients A, B, C, and D. This approach is more general and can be applied to any potential with a well-defined boundary condition at infinity.
Related to What Are the Boundary Conditions for l=0 with Negative Energy?
What are boundary conditions with l=0?
Boundary conditions with l=0 refer to the conditions that must be satisfied at the boundary of a system when the quantum number l (angular momentum) is equal to 0. These conditions are important in solving quantum mechanical problems, particularly in the study of atomic and molecular systems.
Why are boundary conditions with l=0 important?
Boundary conditions with l=0 are important because they provide constraints on the solutions of the Schrödinger equation, which describes the behavior of quantum systems. These conditions help determine the allowed energy levels and wavefunctions of the system.
What are the boundary conditions for a particle with l=0 in a 1-dimensional box?
The boundary conditions for a particle with l=0 in a 1-dimensional box are that the wavefunction must be continuous at the boundaries, and the derivative of the wavefunction must be zero at the boundaries. This means that the particle cannot have any angular momentum in the 1-dimensional box.
How do boundary conditions with l=0 affect the energy levels of a system?
The boundary conditions with l=0 determine the possible energy levels of a system. For example, in the case of a particle in a 1-dimensional box, the boundary conditions require that the energy levels must be quantized and only certain values are allowed. This is known as the quantization of energy levels.
Can the boundary conditions with l=0 be applied to all quantum systems?
Yes, the boundary conditions with l=0 can be applied to all quantum systems, although the specific conditions may vary depending on the system. In general, these conditions are used to determine the allowed energy levels and wavefunctions of a system, and are an important tool in understanding the behavior of quantum systems.
