What are the components of an applied force?
In summary, the concept of applied force acting at an angle involves two component forces - normal and friction. The normal force is perpendicular to the surface while the friction force is parallel to the surface. However, in certain situations, such as when there is no friction between the object and the surface, the applied force will only have a normal component and no friction component. This can lead to confusion and misunderstandings about how forces act in different situations.
Book reader
Something said in my physics textbook really confused me.
The following was written : "Applied Force is our label for a contact force that a person exerts. When an applied force acts at an angle, it is actually a combination of two forces : normal and friction. The component of the applied force that is perpendicular to the surface is a normal force, and the component parallel to the surface is a friction force."
I always thought an applied force acting at an angle was made up of Fa[y] and Fa[x] for the vertical and horizontal components respectively. I questioned my teacher about this and he said that the forces of friction and normal are between the surface of the object and the hand, not between the object and the ground, however that didn't help much at all. Could anyone provide some clarification with regards to the statement above please? Thank you.
Consider this example - pushing a book kept on a table, at an angle, say, ##θ## with the vertical. You are now pushing the book against the table, ##and## parallel to the table. For simplicity, let us assume that there exists no friction between the book and the table, and friction can exist beteen the book and the man, only.
Suppose the book moves horizontally. Which force is responsible for this?
How is this force generated? Do you get it now?
Your confusion comes from intent versus consequence.
Consider an extreme case of your thought experiment, a massless block jammed between two frictionless plates. The plates exert a normal force on the block. Now you intend to apply a force on the block parallel to the plates. But since there is no friction and the block is massless, there is no resistance. In consequence, you are simply not able to apply a force.
Now back to the original example. If you try to push down at an angle on a frictionless horizontal surface, you cannot actually apply such a force. The force you apply will be purely normal to the surface.
Related to What are the components of an applied force?
1. What is an applied force?
An applied force is a force that is exerted on an object by another object or by a person. It causes the object to accelerate in the direction of the force.
2. What are the components of an applied force?
The components of an applied force are the magnitude and direction of the force. The magnitude is the strength or size of the force, while the direction is the path or angle in which the force is being applied.
3. How do you calculate the magnitude of an applied force?
The magnitude of an applied force can be calculated using the formula F = ma, where F is the force in Newtons (N), m is the mass of the object in kilograms (kg), and a is the acceleration in meters per second squared (m/s^2).
4. How do the components of an applied force affect an object?
The direction of an applied force determines the direction in which the object will accelerate, while the magnitude of the force determines how fast the object will accelerate. If the force is applied in the same direction as the object's motion, it will speed up. If the force is applied in the opposite direction, it will slow down or even come to a stop.
5. What are some real-life examples of applied forces and their components?
Air resistance is an example of an applied force with both magnitude and direction. The strength of the air resistance depends on the speed and size of the object, as well as the density of the air. Another example is a person pushing a shopping cart. The force exerted by the person is the magnitude, and the direction of the force determines the direction in which the cart will move.
