What Are the Dimensions of Hilbert Space Elements in Quantum Mechanics?
Ravi Mohan
TL;DR Summary
Quick basics revision
Hi Fellas! My first post after a long hiatus from forums. Feeling nostalgia (this is the place where it all began, my fuel for quantum fascination so to speak).
I am revisiting the mathematical formulation of quantum mechanics with the dimensional (MLT) perspective. I want to understand what are the dimensions of Hilbert space elements, within the context of quantum mechanics. I was thinking of the elements as dimensionless but am stuck in the logical reasoning.
Consider an element of (rigged?) Hilbert space ##\mathcal{H}## with operators having continuous spectral decomposition, in the sense the insertion or completeness is represented by
$$\hat{\mathbb{1}} = \int dx|x\rangle\langle x|,$$
were ##x## is continuous and all those usual gory specifications.
I am interested in knowing the role of high school dimensional analysis played here. For that I consider a unit norm state vector ##|\Psi\rangle##. According to the premise I started with, ##|\Psi\rangle## should have the dimensions of ##[M^0L^0T^0I^0\Theta^0J^0]## (symbols have usual meaning).
Now I start the quantum gymnastics
\begin{align}
|\Psi\rangle &= \hat{\mathbb{1}}|\Psi\rangle \\
&= \int dx|x\rangle\langle x| \cdot |\Psi\rangle\\
&= \int dx \psi(x)|x\rangle
\end{align}
I see no issue in first equation because ##|\Psi\rangle## and ##\hat{\mathbb{1}}## are dimensionless.
In second equation, I don't know how to distribute dimensions. My common sense senses that since ##\psi(x)## is to be interpreted as "wavefunction" its units need be ##L^{-0.5}##. But then the inner product looses its value, in the sense that ##\psi(x) = \langle x|\Psi\rangle## where ##|\Psi\rangle## and the element of dual vector space ##\langle x|## are supposed to be dimensionless. How do I reconcile?
Maybe it is nothing, and maybe I need jolting back to undergrad, a little lesson in dimensional analysis should be helpful!
Thanks!
H
Your argument suggests that ##|\Psi>## has no physical dimension.
<\Psi|\Psi>=1 when normalized. Do you have an uneasiness with it ?
Are you suggesting dual vector space has inverse dimensions?
No, both ##<\Psi|## and ##|\Psi>## have no dimension.
And what about ##\psi(x)##?
##L^{-1/2}## as you said because <x| has dimension ##L^{-1/2}##.
\int |x&gt;dx&lt;x|=1 corresponding
L^{-1/2} L^1 L^{-1/2} =L^0=1
[EDIT]
Above is 1 D case. ##|\psi|^2## is probability density per unit length which has dimension ##L^{-1}##.
For 3D case
\int\int\int |\psi|^2 dxdydz=1 and ##|\psi|^2## is probability density per unit volume which has dimension ##L^{-3}##.
So you are suggesting ##\langle x|##, and element of the dual of same hilbert space ##\mathcal{H}## is now equipped with some dimension?
For clarity ##|\Psi\rangle, |x\rangle \in\mathcal{H}##.
Or maybe, something like
$$\int_{x}^{x+dx} dx|x\rangle\in \mathcal{H}.$$
But yeah, no.
<x| ,|x> have dimension ##L^{-1/2}##
<p|, |p> have dimension ## [ML/T] ^ {-1/2}## or so.
They do not belong to ordinally Hilbert Space as you said in OP.
For confirmation
&lt;x|x&#039;&gt;=\delta(x-x&#039;)
has dimension ##L^{-1}## because
\int \delta(x-x&#039;)dx&#039;=1
corresponding
L^{-1}L^1=L^0
Yeah so what is it?
About the rigged Hilbert space that I need more understanding on?
I don't see any reconciliation, yet!
Well there is a particular reason for me to post here. Reading vague literature is not my cup of tea, anymore ...
Both ##<\Psi|## and ##|\Psi>## have no dimension.
Inner product ##<\Psi|\Psi>## has no dimension. Value 1 when normalized.
Both ##<x|## and ##|x>## have dimension ##L^{-1/2}##.
Inner product ##<x|x'>=\delta(x-x')## has dimension ##L^{-1}##.
##\psi(x)=<x|\Psi>##
##\psi^*(x)=<\Psi|x>## so from the above
Both ##\psi(x)## and ##\psi^*(x)## have dimension ##L^{-1/2}##.
Component product ##\psi(x)\psi^*(x)## has dimension ##L^{-1}##.
Inner product ## \int \psi(x)\psi^*(x) dx## has no dimension, Value 1 when normalized.
Do you find any problems on the above ?
Moderator's note: Thread level changed to "I". This is not "B" level material.
NO
Likes anuttarasammyak
