MHB What are the domain and range for the inverse function $f^{-1}$ of $f$?
To find the inverse function \( f^{-1} \) of \( f(x) = 5 \sin x + 2 \) over the interval \( -\frac{\pi}{2} \leq x \leq \frac{\pi}{2} \), exchange \( x \) and \( y \) and solve for \( y \), resulting in \( f^{-1}(x) = \sin^{-1}\left(\frac{x-2}{5}\right) \). The domain of \( f(x) \) is \( [-\frac{\pi}{2}, \frac{\pi}{2}] \), which corresponds to the range of \( f^{-1}(x) \). The range of \( f(x) \) can be determined by evaluating \( 5 \sin x + 2 \), leading to a range of \( [1, 7] \). Consequently, the domain of \( f^{-1}(x) \) is also \( [1, 7] \). Thus, the domain and range relationships between the function and its inverse are established clearly.
karush
MHB
Find the inverse function $f^{-1}$ of $f$.
Find the range of $f$ and the domain and range of $f^{-1}$
$$f(x)=5 \sin x +2; \quad -\frac{\pi}{2}\le x \le \frac{\pi}{2}$$
exchange x for y and solve for y
\begin{align*}\displaystyle
x&=5\sin y + 2 \\
\frac{x-2}{5}&=\sin y
\end{align*}
multiply $\sin^{-1}$ to both sides
$$\sin^{-1}\left( \frac{x-2}{5}\right)
=\sin^{-1}(\sin y)=f^{-1}(x)$$
ok how do get the range of $f$ and domain and range of $f^{-1}$
Mathematics news on Phys.org
Recall that the domain of $f(x)$ is the range of $f^{-1}(x)$, and the range of $f(x)$ is the domain of $f^{-1}(x)$.
So, you are given that the domain of $f(x)$ is $[-\frac{\pi}{2},\frac{\pi}{2}]$.
Therefore, the range of $f^{-1}(x)$ is $[-\frac{\pi}{2},\frac{\pi}{2}]$
Use this idea to determine the range of $f(x)$ and domain of $f^{-1}(x)$. (they should be the same thing)
We know that,
$-1 \leq sinx \leq 1$
If that is the range for $sinx$ then how will that change for $5sinx+2$?
A technical point: please don't say "multiply sin^{-1} to both sides". That sounds like you think "sin^{-1}" is a number. What you mean is "apply the function sin^{-1} to both sides".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
