What are the essential precalculus concepts for success in calculus 1?
  • MHB
  • Thread starter mathdad
In summary: I appreciate your help.In summary, the problem is equivalent to saying:Consider the circle centered at (-2,3) with radius 6 and the line y = 1. What are the x-coordinates of the point(s) of intersection between the circle and the line?Let's look at a graph:We have the following equation in $t$:(t+2)^2+2^2=6^2Arrange in standard quadratic form:t^2+4t-28=0Applying the quadratic formula, we obtain:t=-2\pm4\sqrt{2}
mathdad
1,283
Find values of t such that the points (-2, 3) and (t, 1) are 6 units apart.
The set up is:
6 = sqrt{(t + 1)^2 + {(1 - 3)^2}
I now square both sides to solve for t.
Correct?
Mathematics news on Phys.org
The set up is:
Correct?
You have the right idea to use the distance formula, however you haven't applied it correctly. What you want is:
\(\displaystyle 6=\sqrt{(t-(-2))^2+(1-3)^2}\)
You see, the distance formula states that the distance $d$ between the points $\left(x_1,y_1\right)$ and $\left(x_2,y_2\right)$ is given by:
\(\displaystyle d=\sqrt{\left(x_2-x_1\right)^2+\left(y_2-y_1\right)^2}\)
Are you saying that 6 should be squared?
You will want to square both sides to solve for $t$, but do you see how the equation you stated is incorrect?
I see my error in the radicand. I usually post my questions after work between 1:30am and 3am. I am tired after midnight. I have a split days off schedule. On such a schedule, I must take advantage of every minute to get things done. I am off on Tuesday and Friday. It's a horrible schedule but what can I do?
The problem is equivalent to saying:
\(\displaystyle (t+2)^2+2^2=6^2\)
\(\displaystyle t^2+4t-28=0\)
\(\displaystyle t=-2\pm4\sqrt{2}\)
Sorry but I cannot see the line y = 1.
If your browser isn't rendering images well, you can sketch the circle and line pretty easily. Plot the point (-2,3) then one at a time move up, right, down, left 6 units from the center and plot points there and then connect the 4 points with a circle. Then draw the horizontal line y = 1 to get an idea where the values of t will be, as they will be the x-coordinates of the points of intersection between the circle and line.
Ok. I can now see the entire circle and the line y = 1.
- - - Updated - - -
Mark,
Thank you for your help. I've decided not to post every question from the David Cohen precalculus textbook. This task will take forever to accomplish. I will instead focus on the questions every student should know how to solve before going to calculus 1. I love my precalculus textbook but it is simply too lengthy.
FAQ: What are the essential precalculus concepts for success in calculus 1?
What is the purpose of finding values of t in science?
Finding values of t, also known as calculating the t-statistic, is a statistical method used to determine the significance of a relationship or difference between two or more groups or variables. This is important in science as it allows researchers to make informed conclusions and decisions based on the data.
How is the t-statistic different from other statistical methods?
The t-statistic is specifically used for small sample sizes, typically less than 30, and is dependent on the variability of the data. Other statistical methods, such as z-tests and ANOVA, are used for larger sample sizes and are not as sensitive to data variability.
What is the formula for calculating the t-statistic?
The formula for the t-statistic is (x̄ - μ) / (s / √n), where x̄ is the sample mean, μ is the population mean, s is the sample standard deviation, and n is the sample size. This formula is used to compare the means of two groups.
How is the t-statistic used in hypothesis testing?
The t-statistic is used to calculate the p-value, which is then compared to a predetermined significance level (usually 0.05). If the p-value is less than the significance level, the results are considered statistically significant and the null hypothesis is rejected. This means that the observed relationship or difference between groups is unlikely to be due to chance.
Can the t-statistic be used for non-numerical data?
No, the t-statistic is only appropriate for numerical data. For non-numerical data, other statistical methods such as chi-square tests or non-parametric tests should be used.
9K
