What Are the First Two Terms of sin(sin(2x))?
  • MHB
  • Thread starter Guest2
  • Tags
    Terms
In summary, the conversation discusses finding the first two terms of the series for $\sin(\sin(2x))$, which involves expanding the nested sine functions using the power series for sine. The summary also mentions that the third term in the expansion was originally missed, but it should be included as $\displaystyle \frac{8x^3}{3}$.
Guest2
193
I'm asked to find first two terms of the series $\sin(\sin(2x))$.
$\sin(t) = t-\frac{t^3}{3!}+\frac{t^5}{5!}-\cdots$
$\sin(2x) = 2x-\frac{2^3x^3}{3!}+\frac{2^5x^5}{5!}-\cdots$
$\displaystyle \sin(\sin(2x)) = (2x-\frac{2^3x^3}{3!}+\frac{2^5x^5}{5!}-\cdots)-\frac{(2x-\frac{2^3x^3}{3!}+\frac{2^5x^5}{5!}-\cdots)^3
}{3!}+\cdots$
The cubed term and those beyond don't contribute anything to the first two terms, so
So $\sin(\sin(2x)) = 2x-\frac{2^3x^3}{3!}+\cdots$
However, this is wrong. What have I missed?
}{3!}+\cdots$
You missed an $\displaystyle \begin{align*} x^3 \end{align*}$ term...
You're right, thanks. So the answer is $\displaystyle \sin(\sin(2x)) = 2x - \frac{8x^3}{3} + \mathcal{O}{(x^4)}.$
FAQ: What Are the First Two Terms of sin(sin(2x))?
What is the first two terms of sin(sin(2x))?
The first two terms of sin(sin(2x)) are 2x and (2x)^3/3!.
How do you find the first two terms of sin(sin(2x))?
To find the first two terms of sin(sin(2x)), you can use the Maclaurin series expansion for sin(x) and substitute 2x for x.
Can you simplify the first two terms of sin(sin(2x))?
Yes, the first two terms of sin(sin(2x)) can be simplified to 2x - (4x^3)/3!.
What is the significance of the first two terms of sin(sin(2x))?
The first two terms of sin(sin(2x)) represent the first two non-zero terms in the Maclaurin series expansion of sin(sin(2x)). They can be used to approximate the value of sin(sin(2x)) for small values of x.
How can the first two terms of sin(sin(2x)) be applied in real-life situations?
The first two terms of sin(sin(2x)) can be applied in fields such as physics, engineering, and mathematics to model and analyze oscillatory systems, such as pendulums and waves. They can also be used to estimate the behavior of these systems for small angles or amplitudes.
