What are the forces on a cell in a tree vs on the surface of a tree
In a tall tree, a cubic cell at 1 m height experiences forces primarily from its weight, calculated as F = ma = t(9.8). Cells surrounding it do exert normal forces, contributing to the overall force dynamics, which are not uniformly distributed due to varying material properties and external factors like wind. As the height of the cell increases, the weight from above decreases, impacting the net forces acting on it. Analyzing these forces is complex, especially if considering deformable elements, leading to statically indeterminate scenarios. Understanding these interactions may require simulations to visualize stress patterns and structural behavior under load.
bo reddude
Not a homework, just wondered all of sudden.
f = ma
Hey everyone.
Let's say you have a tall tree. say, 10 m tall. Take a cubic cell 1mm in dimensions. Suppose the cell is at 1 m high in the center of the trunk of the tree.
What are the forces acting on the cell? let's say tree cell's mass is t grams.
its weight is F= ma = t (9.8) = 9.8 t
it's exerting normal forces to the cell below, above and all around it? or no? Do cells around it exert normal forces? What happens to the sum of these forces? is there a diagram that shows this or similar scenario?
What about a same dimension cell on the surface of the tree at the same height? what are the forces acting on that?
What happens if I were to change the height of the cell to 2 m? it has less number of cells above it, so it should experience less weight from above?
I don't know where to begin to answer some of these questions. Any help is appreciated
The net vertical forces on a horizontal slice through the tree obviously equal the weight above it, but these are not uniformly distributed across the slice. The newer growth at the perimeter will be somewhat plastic, so cannot bear much load.
Winds, and any tilt of the trunk, will also shift the load sideways. One side may even be under tension.
If the cells are larger, there are fewer of them. But each one weighs more. The result is that both calculations will yield the approximately the same results.
A difficulty with analyzing large rigid structures by breaking them into small cells is that the result is statically indeterminate. There are many patterns of internal force that could support the structure. You cannot determine by simply looking at the large scale forces on the structure which internal pattern of stresses is present.
What you could do would be to set up a simple structure like a rectangular tower in an unstressed configuration, assume some figures for the bulk modulus (how it compresses under pure pressure) and the shear modulus (how it deforms under a shear load) and slowly relax the structure to see what shape it assumes and what pattern of stresses and forces results. This would require some programming skill.
I have no experience with finite element analysis, but this is how I would proceed.
If you got to the point of having a working simulation (learning a lot of programming in the process), you would probably discover that there are a number of ways in which a tower built from soft blocks can fall down.
bo reddude said:
Homework Statement: Not a homework, just wondered all of sudden.
Relevant Equations: f = ma
Correct. The higher one goes up the tree, the less weight is bearing down. Stands to reason, doesn't it. The most highest top cell has zero weight acting from above acting upon it.
One can assume that the tree 'elements' are rigid, homogenous and not deformable, and that all elements at one height section experience only vertical forces.
If the assumption is that the elements are deformable, then the analysis and equations become somewhat more complicated,
