- #36
cjm181
- 69
- 1
Hey up, ok i will have a look tonight at some waveforms and feed back. I did assume the graph C in post 26 was correct. I am guessing it is not.
I know a little about PWM control of LEDs. I have had a dabble at the arduino, and also fly rc helis where i believe the servo position is obtained by PWM.
Are you saying the zener produces a square wave in this setup?I understand it will output a steady voltage, and i know it will resist flow at a voltage less than its knee voltage. Let me draw some stuff out later tonight.
I didnt estimate the brightness of the led was an issue with a normal DC suppy. I know from athe arduino if you give it full DC, or 100% pwm, then the led is on full. (edit, almost 100% PWM, significantly more on duty time than off)
Also as the opto isolator is only reading high or low, there will be a threshold to an amount of light it will call as on, and an amount of light it calls off?, so as long as when we want a high output the light from the led exceeds this then we are good?
I will come back with some wave forms later tonight
