Noismaker
- 2
Derivability of function refers to the mathematical concept of finding the rate of change of a function at a specific point. It is a fundamental concept in calculus and is used to understand the behavior of a function over a given interval.
To determine if a function is differentiable at a certain point, you need to check if the limit of the difference quotient (the change in y divided by the change in x) exists as the change in x approaches 0. If the limit exists, the function is differentiable at that point.
The main difference between differentiability and continuity is that a function can be continuous at a point without being differentiable at that point. Continuity means that the function has no breaks or holes, while differentiability means that the function has a well-defined slope at that point.
No, a function cannot be differentiable but not continuous. Differentiability implies continuity, since a function must be continuous at a point for it to be differentiable at that point.
The concept of differentiability is used in many real-life applications, such as physics, engineering, and economics. It is used to calculate rates of change, determine the maximum and minimum values of a function, and understand the behavior of a system over time. For example, it can be used to calculate the velocity of a moving object, the growth rate of a population, or the rate of change of stock prices.
