What are the Intercepts of the Sine Wave $y=\sin{2(x-\frac{\pi}{4})}$?
In summary: Thanks for the correction.In summary, the conversation is discussing finding the x intercepts of the function y=sin(2(x-pi/4)). The group discusses using the fact that sin(x)=0 when x=npi for any integer n, and solving for x using this information. They also mention using Ackbach's method and decoding LaTeX.
karush
MHB
3,269
how do you find the x intercepts of this
thot if 0=sin(2x-(pi/2)) then 0=2x-(pi/2) since sin(0)=0 but doen't look it
still don't know how to convert this to latex
K
Mathematics news on Phys.org
You're on the right track. Start with y=0 and then like you said use the fact that sin(0)=0. So solve \(\displaystyle 2x-\frac{\pi}{2}=0\). That is only one of possibly infinite intercepts though. For what values of theta, does \(\displaystyle \sin(\theta)=0\)? Not just at 0. How can you generalize these?
well i did this 0=2(x-(pi/4)) so from this looks like if x = (pi/4) then the intercepts this plus K(pi/4)+pi ?
Not quite sure I would agree with the solutions so far. $\sin(z)=0$ when $z=n\pi$, for any integer $n$. So, set $2(x-\pi/4)=n\pi$ and solve for $x$. What do you get?
I would use Ackbach's method to solve this. We know that $\sin(x) = 0$ when $x = n\pi$ where n is an integer (you can check this by graphing the result and using the periodicity of sin(x) to extend it)
Thus $2\left(x- \frac{\pi}{4}\right) = n\pi \Leftrightarrow x - \frac{\pi}{4} = \frac{n\pi}{2}$
Add $\frac{\pi}{4}$ to both sides to get the general set of solutions.
Typically these questions ask for solutions between $0$ and $2\pi$. If this is the case then $n=0,1,2$
To render latex, use a single dollar sign at each end of your latex (or a double dollar sign to centre it, again at each end). http://www.mathhelpboards.com/showthread.php?27-How-to-use-LaTeX-on-this-site has more information including how to decode someone else's (although I go with the quote the post and look for myself method :cool:)
Code:
becomes $2\left(x- \frac{\pi}{4}\right) = n\pi \Leftrightarrow x - \frac{\pi}{4} = \frac{n\pi}{2}$
Doh! Sorry guys and thanks for catching my mistake. Clearly it's not \(\displaystyle 2 \left(x-\frac{\pi}{4} \right) + n\pi\) but when \(\displaystyle 2 \left(x-\frac{\pi}{4} \right) = n\pi\)
FAQ: What are the Intercepts of the Sine Wave $y=\sin{2(x-\frac{\pi}{4})}$?
What are intercepts of a sine wave?
The intercepts of a sine wave refer to the points on the graph where the curve crosses the x-axis. These points are also known as the x-intercepts and represent the values of the independent variable (usually time) at which the output of the function is equal to zero.
How do you find the intercepts of a sine wave?
To find the intercepts of a sine wave, you can set the function equal to zero and solve for the values of the independent variable that make the output equal to zero. This can be done algebraically or by graphing the function and identifying the points where the curve crosses the x-axis.
What do intercepts of a sine wave represent?
The intercepts of a sine wave represent the points in time where the output of the function is at its minimum or maximum value. These points can be used to determine the amplitude and period of the sine wave.
Can a sine wave have more than two intercepts?
Yes, a sine wave can have an infinite number of intercepts. This is because the function repeats itself infinitely in both the positive and negative direction. However, in most cases, only the first two intercepts are considered as they provide enough information to determine the characteristics of the sine wave.
How do intercepts of a sine wave relate to its frequency?
The intercepts of a sine wave do not directly relate to its frequency. However, the frequency can be determined by calculating the distance between two consecutive intercepts. The higher the frequency, the closer together the intercepts will be.
