MHB What are the intervals on the number line for | x + 5 | ≥ 2?
  • Thread starter Thread starter mathdad
    intervals
The inequality | x + 5 | ≥ 2 indicates that x is at least two units away from -5 on the number line. This results in two intervals: x ≥ -3 and x ≤ -7. The solution can be represented as the intervals (-∞, -7] and [-3, ∞). Both intervals correctly reflect the conditions set by the inequality. The discussion confirms the accuracy of these intervals.
mathdad
The set of real numbers satisfying the given inequality is one or more intervals on the number line. Show each interval on the number line.
1. | x - 1 | < or = 1/2
Solution:
-1/2 < or = x - 1 < or = 1/2
(-1/2) + 1 < or = x < or = (1/2) + 1
1/2 < or = x < or = 3/2
----[1/2-------3/2]----
Correct?
2. | x + 5 | ≥ 2
Solution:
This question says that x is at least two units away from 5 on the number line.
x + 5 ≥ 2
x ≥ 2 - 5
x ≥ - 3
or
x + 5 ≤ -2
x ≤ - 2 - 5
x ≤ - 7
<---- -7]------[-3---->
Correct?
Mathematics news on Phys.org
Both are correct.
It surely feels good to be right.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
