What are the key mistakes in approaching this work-energy principle problem?
In summary, the problem involves a skater with a mass of 70kg throwing a stone with a mass of 5kg at a velocity of 8m/s on ice with a coefficient of friction of 0.02. The distance the skater will move back depends on the work done by the net force of the stone and the friction, and the correct answer is 0.83m. The solution uses conservation of momentum and the work-energy theorem to solve the problem. However, the approach of calculating the reaction force and applying the work-energy theorem in the original attempt is incorrect.
Radhika Ahuja
A skater with mass 70kg standing on ice throws a stone of mass 5kg with a velocity of 8m/s in the horizontal direction. Find the distance over which the skater will move back if the coeffcient of friction between the skates and the ice is 0.02[/B]
This is how I tried to solve it:
The force with which the stone if thrown = mass of stone x g = 5g
Thus, the reaction force the man experiences is -5g
Now, the net force in with which the person moves back would be (-5g + Force of friction)
And here friction is uN = 0.02x70g = 1.4g
=> Net force with which the person moves back is -5g + 1.4g = -3.6g
The Work done by this force is F.d = Change in Kinetic Energy/the energy that was transferred from the man to the stone
=> F.d = 1/2 x mass of stone x v^2
=> d = (2.5 x 64)/(3.6 x 9.8) ~ 4.53m
However, this answer is incorrect, the correct answer is 0.83m and the solution solves it using power.
I want to understand two things:
- why is this way of approaching it wrong/what am I missing?
- when I see a problem, how should I identify whether a problem will require using the Power equation/how should I approach problems like this in general[/B]
I see two major problems with your approach:
1) The way you calculate the reaction force =-5g is wrong. What you calculate as 5g is the weight of the stone. I think we have insufficient data to calculate the reaction force.
2) The way you apply the work energy theorem. You set the work done on the skater from the net force on him, equal to the kinetic energy of the stone. That is wrong . The work of the net force on the skater is equal to the change in the kinetic energy of the skater.
My question is what is the Power equation that the problem uses? Also in the solution don't they use conservation of momentum in order to calculate the speed of the skater right after he throws the stone?
Also I think the problem implies one critical assumption (I am not so sure about this but anyway I ll state it), that the throwing of stone is done within infinitesimally small time ##dt## so the reaction force is considered to be infinite (so that the impulse ##Fdt=\infty\cdot 0## of the reaction force is finite and equal to the momentum of the stone) and its of no further use to this problem.
Anyway can you post fully the solution that you read, I want to figure out some things about it.
The energy comes from the man's muscle, not from any KE the man had... and if it had come from the man's KE then that would have been negative work, slowing the man down.
Delta2 said:
I think the problem implies one critical assumption (I am not so sure about this but anyway I ll state it), that the throwing of stone is done within infinitesimally small time dt
Technically that is true, because of the friction, but the effect would be minuscule.
You're right, they use conservation of momentum. Thank you!
Related to What are the key mistakes in approaching this work-energy principle problem?
1. What is the Work-Energy Principle?
The Work-Energy Principle is a fundamental concept in physics that states that the work done on an object is equal to the change in its kinetic energy. This principle helps us to understand the relationship between work and energy and how they are interconnected.
2. How is the Work-Energy Principle applied?
The Work-Energy Principle can be applied to various systems, such as a moving object, a rotating object, or a system of multiple objects. It is used to calculate the work done by forces on an object and how this work affects the object's kinetic energy.
3. What is the equation for the Work-Energy Principle?
The equation for the Work-Energy Principle is W = ΔK, where W represents work, and ΔK represents the change in kinetic energy of the object. This equation can also be written as W = (1/2)mv2f - (1/2)mv2i, where m is the mass of the object, vf is the final velocity, and vi is the initial velocity.
4. What is the significance of the Work-Energy Principle?
The Work-Energy Principle is significant because it allows us to understand and analyze the behavior of objects in motion. It helps us to determine the work done by various forces on an object and how this work affects the object's energy. This principle is also crucial in solving problems related to motion and energy in physics.
5. Can the Work-Energy Principle be violated?
No, the Work-Energy Principle is a fundamental law of physics and cannot be violated. The total amount of work done on an object must always be equal to the change in its kinetic energy. If the work done is not equal to the change in kinetic energy, it means that there are other factors or forces involved that were not taken into consideration.
