MHB What are the last four digits of a_{2012}?
  • Thread starter Thread starter anemone
The sequence defined by \( a_n \) starts with \( a_1=1 \) and follows the recurrence relation \( a_{n+1}=\left\lfloor a_n+\sqrt{a_n}+\dfrac{1}{2} \right \rfloor \). It is proven that \( a_{2n} = n^2 + 1 \) and \( a_{2n+1} = n^2 + n + 1 \), leading to the conclusion that \( a_{2012} = (1006)^2 + 1 \). The last four digits of \( a_{2012} \) are calculated to be 1237. However, a participant suggests an alternative calculation resulting in the last four digits being 2037, prompting a correction in the discussion.
anemone
MHB
POTW Director
Let $a_n$ be a sequence such that $a_1=1$ and $a_{n+1}=\left\lfloor a_n+\sqrt{a_n}+\dfrac{1}{2} \right \rfloor$.
What are the last four digits of $a_{2012}$?
Mathematics news on Phys.org
[sp]$a_{2n} = n^2+1$. To prove that by induction, notice that $n^2+1 < \bigl(n+\frac12\bigr)^2 = n^2+n+\frac14 < n^2+n+1$. Therefore $$\sqrt{n^2+1} < n+\tfrac12 < \sqrt{n^2+n+1}.$$ It follows that $$a_{2n} + \sqrt{a_{2n}} + \tfrac12 = n^2+1 + \sqrt{n^2+1} + \tfrac12 <n^2+ \bigl(n+\tfrac12\bigr) + \tfrac12 = n^2+n+1$$ (so that $a_{2n+1} = n^2+n+1$). Then $$a_{2n+1} + \sqrt{a_{2n+1}} + \tfrac12 = (n^2+n+1) + \sqrt{n^2+n+1} + \tfrac12 > (n^2+n+1) + \bigl(n+\tfrac12\bigr) + \tfrac12 = n^2+2n+2 = (n+1)^2+1,$$ so that $a_{2n+2} = (n+1)^2+1.$ That completes the inductive step, and shows in particular that $$a_{2012} = (1006)^2 + 1 = (10^3+6)^2 = 10^6 + 12\cdot 10^3 + 36 + 1 = 10^6 + 12\cdot 10^3 + 37,$$ so that its last four digits are $1237.$[/sp]
@Opalg: (Bow)
-Dan
Nice!
But I'll pick 2037 as answer.
I like Serena said:
Nice!
Erm, yes. (Angry)
Thanks for participating Opalg!
Your method seems so perfect to me.
My solution:
Observe that
$a_1=1$, $a_2=2$, $a_3=3$, $a_4=5$,$a_5=7$, $a_6=10$, $a_7=13$, $a_8=17$, $a_9=21$, $a_{10}=26$, $\cdots$
We are asked to find the last 4 digits of $a_{2012}$ term, so, if we only consider the terms $a_2=2$, $a_4=5$, $a_6=10$, $a_8=17$, $a_{10}=26$, $\cdots$, we see that
1.
the differences between the terms made up an arithemetic sequence (3, 5, 7, 9, ...), since
and hence we get the sum of the first $n$ terms of the sequence (3, 5, 7, 9,...) be
$S_n=\dfrac{n}{2}(2(3)+(n-1)(2))=n(n+2)$.
2. Once we recognize this pattern, we can easily find whichever term that we would like to, says, if we want to look for the 5th term in this sequence ($2,5,10,17,26,37,\cdots$), then what are we going to do to find that fifth term is by adding the first term, that is 2 to the sum of the first 4 terms of the arithmetic sequence (3, 5, 7, 9, ...), i.e.
$a_5=2+4(4+2)=26$
Therefore, if we look for the 1006th term in the sequence ($a_2=2$, $a_4=5$, $a_6=10$, $a_8=17$, $a_{10}=26$, $\cdots$), that means we are actually find the $a_{2012}$ of the given sequence in the original problem.
So, $a_{1006}=2+1005(1005+2)=1012037$, thus, the last four digits of $a_{2012}$ is 2037.
My solution:
Observe that
1.
$a_5=2+4(4+2)=26$
So, $a_{1006}=2+1006(1006+2)=1012037$, thus, the last four digits of $a_{2012}$ is 2037.
only one word is sufficient to describe your solution
elegant
My solution:
Observe that
1.
$a_5=2+4(4+2)=26$
it should be :
Albert said:
it should be :
Oops!:o You're absolutely right! I will fix my previous post and thank you so much for pointing this out, Albert!:)
