What are the limits on resolution of STORM/PALM?
In summary, STORM/PALM (Stochastic Optical Reconstruction Microscopy/Photoactivated Localization Microscopy) is a super-resolution imaging technique that uses fluorescence microscopy to achieve resolutions beyond the diffraction limit of light. It works by using photoactivatable fluorescent probes that can be switched on and off multiple times, allowing for the reconstruction of high-resolution images. The resolution is limited by the size of the probe and the precision of the localization algorithm, currently at around 10 nanometers. Compared to other super-resolution techniques, STORM/PALM has the advantage of being able to image live cells and tissues without damage, and has a higher resolution. Its potential applications include studying molecular interactions, imaging cellular structures, and understanding disease mechanisms at the nan
Jon.G
45
I know localisation microscopy 'beats' the limit on resolution by activating individual sources and rendering a final image, but what are the limits that prevent the resolution of the images of these individual fluorophores?
Is it just the number of photons collected?
Cheers
Related to What are the limits on resolution of STORM/PALM?
What is STORM/PALM imaging?
How does STORM/PALM imaging work?
STORM/PALM imaging works by using photoactivatable fluorescent probes that can be switched on and off multiple times. By imaging the same area multiple times, the location of each probe can be determined and a high-resolution image can be reconstructed.
The resolution of STORM/PALM imaging is limited by the size of the fluorescent probe used and the precision of the localization algorithm. The current limit for STORM/PALM imaging is around 10 nanometers.
What are the advantages of STORM/PALM over other super-resolution techniques?
STORM/PALM has the advantage of being able to image live cells and tissues without causing damage, as it uses low levels of light. It also has a higher resolution compared to other super-resolution techniques.
What are some potential applications of STORM/PALM?
STORM/PALM has a wide range of potential applications, including studying the structure and dynamics of molecular interactions, imaging cellular structures and organelles, and understanding disease mechanisms at the nanoscale level.
