What are the meanings of coordinates ?
In summary: Hello, hiyok! :smile:In summary, a stationary clock at a distance from the origin will be going at a different rate than a clock at the same distance but near the origin. There is no such thing as "the" coordinate time. You could check the metric to see under what conditions d(tau) = dt.
hiyok
109
Hello, I have a question in GRT. Suppose one is going to obtain the gravitational field of a point mass. He at first sets up a coordinate system. E.G., he may imagine laying out three rods throughout the space and put a clock somewhere. This clock may be put still at the origin of the rods frame or somewhere else. Now my question is, what is the difference?
To put it in another way: suppose we use Swartzchild coordinate system, and then how do know by which clock the coordinate time is taken, just from the form of the metric?
Hello hiyok! :smile:
(btw, it's Schwarzschild (meaning "black shield") :wink:)
hiyok said:
… suppose we use Swartzchild coordinate system, and then how do know by which clock the coordinate time is taken, just from the form of the metric?
I don't understand :confused:
stationary clocks at different distances from the origin will be going at different rates …
there's no such thing as "the" coordinate time.
You could check the metric to see under what conditions d(tau) = dt. In your case, t is the time read out on clocks arbitrarily distant from the gravitating body and at rest with respect to it. Verify this by letting dr=dtheta=dphi=0 and then letting r become large.
Hi, Tiny-tim, thanks for correcting my spelling !
Obviously, if one intends to solve Einstein's equation, he must input the energy-momentum tensor, whose form clearly hinges on which frame of reference has been chosen. A complete frame of reference involves necessarily a clock. So, the question is, what is the relation between the coordinate "t" in Schwarzschild metric and the reading of the clock he uses to record the motion of the point mass (He records the motion so as to obtain the energy-momentum tensor) ?
hiyok said:
… which frame of reference has been chosen. A complete frame of reference involves necessarily a clock. So, the question is, what is the relation between the coordinate "t" in Schwarzschild metric and the reading of the clock he uses to record the motion of the point mass (He records the motion so as to obtain the energy-momentum tensor) ?
General Relativity doesn't really have frames of reference.
As ZikZak :smile: says …
:wink:
Hello, ZikZak. Related to your reply, other questions form in my mind: (1)Is that a generic rule to spot clocks? (2)Given a metric, how does one differentiate time coordinate and space coordinates?
(1) I don't know what you mean by "generic rule for spotting clocks." Your question was about under what conditions the t coordinate in the Schwarzschild metric was the proper time.
(2) I don't know what a "time coordinate" or a "space coordinate" is. Time and space are relative; only spacetime intervals are invariant. If you wish to check whether a certain short interval is timelike or spacelike, use the metric to determine whether ds^2 is positive or negative for that interval.
FAQ: What are the meanings of coordinates ?
What is the purpose of coordinates in science?
Coordinates are used in science to specify the location of a point or object in space. They allow scientists to accurately describe and measure the position of objects, as well as track their movement over time.
How are coordinates represented?
Coordinates are typically represented as a set of numbers or values that correspond to specific directions or axes. In two-dimensional space, coordinates are often represented as x and y values, while in three-dimensional space, coordinates may include an additional z value.
What are the different types of coordinates used in science?
The most commonly used coordinate systems in science are Cartesian coordinates, polar coordinates, and spherical coordinates. Each of these systems has their own unique way of representing the location of a point in space.
How do scientists determine the coordinates of a point?
The coordinates of a point can be determined by using various tools and techniques such as GPS, maps, and mathematical calculations. Scientists may also use specialized equipment such as telescopes, sonar, or lidar to determine the precise coordinates of objects in space.
Can coordinates be used to represent time?
Yes, coordinates can also be used to represent time in certain cases. For example, in astronomy, coordinates can be used to track the movement of celestial objects over time. In physics, coordinates can also be used to represent the position of an object at a specific point in time.
