MHB What are the normals of a parabola passing through a given point?
  • Thread starter Thread starter Theia
    Parabola
The discussion focuses on finding the normals of the parabola defined by the equation y = 2x^2 + 4x + 7/4 that pass through the point (3, 15/2). Participants are encouraged to demonstrate their understanding of the problem to receive appropriate hints and assistance. The original poster has already solved the problem and presents it as a challenge to the community. The thread emphasizes the importance of engaging with the problem before seeking help. Overall, it fosters a collaborative environment for problem-solving.
Theia
Find all the normals of function $$y = 2x^2 + 4x + \tfrac{7}{4}$$ which goes through the point $$\left( 3, \tfrac{15}{2} \right)$$.
Mathematics news on Phys.org
Why? If you are posting this because you want help with it then you should show us what you do understand about it yourself so that we will know what kinds of hints and help you need.
Do you understand what a "normal" to a graph is? Do you understand that a normal to a graph, at a point, is perpendicular to the tangent to that graph at that point? Can you find the tangent to $y= 2x^2+ 4x+ \frac{7}{4}$.
Notice that $2(3)^2+ 4(3)+ \frac{7}{2}= 18+ 12+ \frac{7}{4}= 30+ \frac{7}{4}= \frac{127}{4}$ not $\frac{15}{2}$ so the given point is not on the curve. You will need to find the tangent line at some point $\left(a, 2a^2+ 4a+ \frac{7}{2}\right)$ then find a so that tangent line passes through (3, 15/4). Once you have found the point and the equation of the tangent, it should be easy to find the normal line.
This thread was posted in our "Challenge Questions and Puzzles" forum, so that means the OP has the solution and finds the problem interesting and so wishes to post the problem as a challenge to the community. (Yes)
By the way, I edited your post to hide anything that might give anything away for those who don't wish to see any hints before attempting to solve it themselves.
Okay, thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
