Bob K
- 13
The Fitzgeral-Lorentz transformation equations describe what is the time, e.g., the timecount, of a clock which has been accelerated or decelerated from an initial reference frame into a different reference frame.
If two identical clocks, C1 and C2, are in an initial reference frame, K, and C2 is accelerated into reference frame, K', there is a difference velocity v between K and K', then the time t in K ≠ the time t' in K' (t ≠ t'), e.g., the timecount of C1 ≠ the timecount of C2.
Mathematics describe physical changes, which are effects, but not necessarily the causes of the effects.
Q1: What is the cause of the effect of the changes of the timecounts of accelerated or decelerated clocks?
A1: _____ (?)
Q2: What is the cause of the effect wherein when C2 is accelerated or decelerated relative to C1 and t in of C1 in K ≠ t' of C2 in K'?
A2: _____ (?)
Perhaps another way to ask the same question may be thus:
When a clock is accelerated, its rate of ticking slows down, and when a clock is decelerated, its rate of ticking speeds up.
Q3: What is the physical cause of a decrease in a clock's rate of ticking when the clock is accelerated and what is the cause of an increase in a clock's rate of ticking when the clock is decelerated?
A3: ______ (?)
A change of a clock's rate of ticking is considered to be time dilation/contraction when the change is a decrease of the clock's rate of ticking or timecount when the clock is accelerated and the change is considered to be time expansion when the change is an increase of the clock's rate of ticking or timecount.
Q4: What is the physical cause of a clock's time dilation/contraction when the clock is accelerated or the clock's time expansion when the clock is decelerated?
A4: _____ (?)
A1: _____ (?)
A2: _____ (?)
A3: ______ (?)
A4: _____ (?)
